Crooked Steering Wheel
Old Aug 8, 2019 | 02:06 PM
Mark250's Avatar
Mark250
During a long vacation trip out west I noticed that my steering wheel is now crooked - probably 1 spline tooth or 5 degrees or so. It was not this way before. 8k miles on the truck. I have never hit any curbs or severe holes/bumps that would be bad enough to cause steering damage or misalignment. The truck still drives perfectly, holds the road easily, and doesn't wander or pull to either side so I don't believe this has anything to do with the steering linkages, but something in the column. I did check all 3 bolts on the column joints and they are all tight. My theory is something shifted while going over a bridge seam or something like that. I probably have a tendency to grip the wheel tight while going over bridges. Anybody else experienced this?
Old Aug 8, 2019 | 04:01 PM
Mkos1980's Avatar
Mkos1980
The wheel itself is only 8 flat sides I believe. I had to adjust mine via the center link by about 1/4 inch of a turn.
Old Aug 9, 2019 | 08:31 AM
Mark250's Avatar
Mark250
Didn't want to mess with the alignment but it looks like this is the only choice. My new '91 F-150 had a crooked steering wheel from the factory. Local dealer was a jerk so I moved the wheel one spline.
Old Aug 9, 2019 | 09:21 AM
Mkos1980's Avatar
Mkos1980
Your wheel must have been severely off as the wheel isn't on splines. It's on like a hexagon and one move over would realllly change the direction of the wheel.
Old Aug 9, 2019 | 09:41 AM
schrod's Avatar
schrod
Aren't the Super Duties like the F150 and use electric steering?
Old Aug 9, 2019 | 09:49 AM
Mkos1980's Avatar
Mkos1980
LoL. Not even close.
