Doublelead
Old Aug 8, 2019 | 11:04 AM
Doublelead's Avatar
Doublelead
Doublelead
Anyone swapped a 385 series into a 57-60 with the Toyota power steering box? I'm trying to settle on what header will fit.
Old Aug 8, 2019 | 07:54 PM
spurredon's Avatar
spurredon
There are some guys around that have put 460's and 429's in their fridges. I have a 429 setting in the barn that I have been thinking about but it is a '72 and that was not a great year for 385 series.
Old Aug 9, 2019 | 01:21 PM
Doublelead's Avatar
Doublelead
Your 429 may have the 72cc combustion chambers making it 11: 1 compression ratio. Check the casting number.
Old Aug 9, 2019 | 09:37 PM
spurredon's Avatar
spurredon
Pretty sure they are D2 and D0 were the desirable ones.
Old Aug 10, 2019 | 02:34 AM
matthewq4b's Avatar
matthewq4b
You are correct in 72 compression ratios across the whole engine line up dropped, the 385 compression ratio was 8.5:1 across the line The only exception to this was the 429 P.I engines that sported the D20E heads. These heads have pushrod guide plates and screw-in rocker studs with a chamber size of about 92 cc's with a compression ratio of about 9:1. The port sizes of the D20E heads are slotted in between the CJ and standard passenger car heads.
Old Aug 14, 2019 | 09:03 AM
Byrd.Dog's Avatar
Byrd.Dog
My 400 fits fine with the CPP steering box. Only clearance issue would be the exhaust manifold. I don't know about the big blocks, but my factory manifold dumps kind of in the center, not the back, so I just ran the exhaust under the oil pan, then turned it back to run next to the passenger side pipe. Might have to look at shorty headers to find a set that dumps more in the center of the block.
raysinvegas
19
Aug 30, 2007 02:53 PM
juchertf100
Jun 14, 2007 08:43 PM
lectricman
Apr 26, 2006 12:00 PM
Dyerstown
Mar 20, 2003 10:19 PM
FE427TP
Jul 29, 2000 12:58 AM
