Sponsored by: Real Truck
Warm up time?
Old Aug 4, 2019 | 07:27 PM
5851a's Avatar
5851a
Warm up time?
2012 6.2, Thursday moved truck out of building to get some patio things. Had sat for a month and fired right up, let it idle for half hour or so and put it back inside. Friday went to gas station to fill it up since it was on half, no warm up, it's only half mile away in the town. Shut it off, filled and it fired but wouldn't keep running. Third try I gave it a little throttle and it slowly recovered and ran fine for trip home. It was about 65 degrees, did it just warm up enough to go from cold to warm transition? Like when a auto choke kicks off but it's still to cold. Wasn't humid out, been rather dry.
Old Aug 4, 2019 | 07:56 PM
ford390gashog's Avatar
ford390gashog
Nope, when you filled up you purged all the gas vapor into the manifold. Common issue, go replace the purge valve before it really makes an issue. The purge valve is stuck wide open.
Old Aug 4, 2019 | 08:28 PM
5851a's Avatar
5851a
Thanks, I will get it done.
Old Aug 4, 2019 | 08:31 PM
ford390gashog
Super simple job, every dealer stocks them and so does Amazon.
