Problems after mods
Old Aug 3, 2019 | 10:31 PM
Deltawolf81's Avatar
Deltawolf81
Problems after mods
Okay. I'm having a major malfunction. I built a true dual exhaust system for my 94 f-150. Its got a 5.0 block and heads out of a 93 t bird. I used hooker long tube block huggers, magnaflow high flow converters, flowmaster 44s, and 2.5 inch plumbing. I put the oxygen sensor back in the same location as the old one.
Now the problem. My long term fuel trim is staying at a -56, which causes the af ratio to go completely rich. I assume this is why I keep blowing o2 sensors. The motor lopes, dies at times, gets crappy fuel mileage, and has no power, especially on hills. I heard through the grapevine that I need to convert to mass air flow sensor because it is a speed density motor. Will this work? And where can I get a conversion kit that doesnt cost an arm and a leg? Any help would be greatly appreciated.
Old Aug 3, 2019 | 10:43 PM
Blurry94's Avatar
Blurry94
What kind of vacuum readings are you seeing at idle, and what is your base timing set at (with the spout connector removed)?
Old Aug 3, 2019 | 10:47 PM
Deltawolf81
20 hg of vacuum and base timing is set at 10 degrees. Also, the only code I'm getting is oxygen sensor indicates lean, which coincides with the -56 fuel trim.
Old Aug 4, 2019 | 12:12 AM
EllieMae94's Avatar
EllieMae94
Your problem sounds eerily similar to mine after
the swap to 351. What heads are those off the T-bird? Did you check for correct push rod length? They could be too long causing the valves to stick open.
Old Aug 4, 2019 | 12:58 AM
Deltawolf81
The block and heads are stock to the t bird. I bolted everything else from my other engine on it. The pistons hypereutectic and the cam is the 351 firing order. That's the only difference other than the plenum.
Old Aug 4, 2019 | 01:07 AM
Phase3's Avatar
Phase3
I had a 94 f150 with ported heads and a trick flow stage 1 that had a plainly noticeable lope with long tube hedman headers and 3 inch dual open exhaust out the back. I had the o2 sensor only into 1 exhaust bank. I really didnt have many driveability issues and it got about 12 mpg with 35 12.50s. I think something else is up. Do you have a low temp thermostat in it? Is the coolant temp sensor working? There should be 2 temp sensors in play one for the gauge and one for the ecu. Thermostat stuck open?
Old Aug 4, 2019 | 01:15 AM
Deltawolf81
I have the stock temp thermostat, the cts is working within specs and the thermostat isnt stuck open. It open and closes at the proper temp.
Old Aug 4, 2019 | 03:02 AM
Phase3's Avatar
Phase3
Possibly an exhaust leak before the sensor?
Old Aug 4, 2019 | 03:19 AM
Deltawolf81
I do have an exhaust leak. Thing is, this truck only has 1 o2 sensor. This sensor is on the passenger bank. The leak is on the drivers bank.
Old Aug 4, 2019 | 03:23 AM
Deltawolf81
I wouldnt think a leak on drivers bank could effect the o2 sensor on opposite bank. Especially with no crossover pipe. Of course I have seen weirder.
Old Aug 4, 2019 | 08:27 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Deltawolf81
.... and the cam is the 351 firing order.
Which camshaft did you use?
Old Aug 4, 2019 | 02:32 PM
Deltawolf81
Everything internal is stock to the 93 h.o. motor. The nokt ons are from my motor. The 302 h.o. has a 351 firing order.
Old Aug 4, 2019 | 03:43 PM
My4Fordtrucks
Yes, I’m aware of that but what I didn’t know/ remember is that the T-bird came with the H.O. engine. You have a ‘94 but don’t say what transmission so do you have Speed Density or MAF?
Old Aug 4, 2019 | 03:57 PM
Scndsin's Avatar
Scndsin
You check you voltages for the sensor? You maybe melted the O2 wires with the new shorties & blew the fuse for the sensor?
Ask me how I know on the exact same truck.
Old Aug 4, 2019 | 05:24 PM
Deltawolf81
sorry. Trannys an m5r2 mazda 5 spd. Its a speed density. (Has the MAP). Fuse for o2 is fine. Wires are good. I made a bracket to hang the harness so it doesnt get against exhaust or any metal.
