Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Split rim/ Widow makers welded?
Old Aug 3, 2019 | 07:55 AM
Cliffy carlock's Avatar
Cliffy carlock
Can the Split rim/ widow maker wheels be welded solid? By a professional welder not me of course.
Old Aug 3, 2019 | 09:24 AM
buzzinduzzin's Avatar
buzzinduzzin
welding widowmaker
assuming you want to mount a tire on finished product ??? I doubt that bead would stretch enough to be mounted. is there a drop center on the rim ?
Old Aug 3, 2019 | 09:42 AM
Cliffy carlock
Not sure what you mean by drop center. Could you explain?
Old Aug 3, 2019 | 09:47 AM
85e150's Avatar
85e150
No and no.
You can reweld the centers into modern drop center tubeless trims. There is a thread on this and I will search it out later.
Old Aug 3, 2019 | 11:25 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
A drop center rim is exactly what the name implies. It allows a car or light truck tire having a flexible bead to fall into the drop while the bead elongates and stretches over the rim lips. No widow maker has a drop center, although some were termed semi-drop center. The rim lips of a widow maker are too tall in most cases, and truck tire beads too rigid, to allow a tire to squeeze past without ruining the tire bead. Stu
Old Aug 3, 2019 | 12:52 PM
85e150's Avatar
85e150
I can't find the exact thread I want.
This one discusses, + and -, Stockton Wheel. Things must have changed there or they wouldn't still be in business. Any input on them?
https://www.ford-trucks.com/forums/1...uper-easy.html
More excellent info in this thread, with additional sources (as of posting date) for moving your centers to drop center tubeless rims.
https://www.ford-trucks.com/forums/1...ears-used.html
Old Aug 3, 2019 | 01:20 PM
truckdog62563
Last I heard Stockton Wheel was still in operation under new management. Frank, the prior owner, passed away. Having heard nothing negative about them since Frank’s passing, I take that as an indicator of where the problem was. Stu
