6 speed swap
Old Mar 29, 2001 | 06:24 PM
cobra1993's Avatar
cobra1993
6 speed swap
89 F250 w/460,5speed, would like to swap out 5 speed for 6 speed. WIll the 6 speed bolt in, or what kind of modifications need to be done. Any help appreciated
Old Apr 21, 2001 | 06:38 AM
pickupman's Avatar
pickupman
6 speed swap
Old Apr 21, 2001 | 01:00 PM
ddestruel's Avatar
ddestruel
6 speed swap
[font size="1" color="#FF0000"]LAST EDITED ON 21-Apr-01 AT 02:02 PM (EST)[/font][p]Hey Cobra,
I confronted this problem when i was toying with the idea of changing my E4od to a 5 or 6 spd. The ford six speed is unique to the Power Stroke, to many head aches to amke a scatter plate adapter which is your only option. But !!!!! You could if you have the $$$$$$ use a Dodge NV 6 speed because dodge in thier infanite wisdom still uses the age old method of Bell housings. The NV 6 spd is sold behind the cummins, so you would need to contact advanced adapters and find out if they have a way to put a NV tranny behind a 460 I was told that thier was an adapter for putting the NV 5 speed behind it and supposedly there are many similarities in the transmissions externally. I stand to be corrected but if you are determined this may give you a direction to look in. Also if you go with the NV tranny you will probably benefit from being able to mate up a NP or NV T-case. How far do you want to got and how much do you want to spend?
Best of Luck to you Buddy.
Dusty
