Battery help
Old Aug 1, 2019 | 05:53 PM
Dieseloholic1's Avatar
Dieseloholic1
Battery help
I was just wondering if the battery in the link will fit a 1985 f250 without doing any modifications thinking about buying them tomorrow
https://www.tractorsupply.com/tsc/product/traveller-31p-heavy-duty-battery?cm_vc=-10005
Old Aug 1, 2019 | 06:12 PM
DarkOverCast's Avatar
DarkOverCast
It'll fit just fine
Old Aug 1, 2019 | 07:56 PM
Dieseloholic1
Originally Posted by DarkOverCast
It'll fit just fine
That's Awesome news
Old Aug 1, 2019 | 09:31 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I use Group 65 the group 31 are too tall for my 93
the Length is a bit longer than a 65 and the 65 is an inch wider than the 31 ... the 65 is 7 1/2" tall and the 31 is 9 3/8 tall
EDIT: wish I could get em to fit mine I don't feel like doing mods.
Old Aug 1, 2019 | 10:40 PM
Dieseloholic1
Hmm good to know what's the highest CCA you can get in a group 65 battery by chance the batteries that's the truck now is 8 7/8 tall
Mods can be a pain for sure
Old Aug 1, 2019 | 11:00 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
CCA is generally 850 but depends on how much money you want to spend you can get 950 too.
my biggest issue is the AIR Intake runs right over the top of the Driver's side battery and bolts to the Radiator support... I just don't want to change it... you may not have that Issue in the older truck, I think I had larger batteries in my 83 F250 they set a bit deeper too.
I get my Batteries from Interstate ... I buy their Re-Furbished and get at least 5 years out of a pair for less than 100 bux... I'm a Cheap Bastid
I've been buying batteries from them folks for many many years now, and if their refurbished looks like Crap don't accept it, the ones I get always look brand new and they give me a year replacement warranty .... it's win win for me South Tx heat kills batteries....
Old Aug 2, 2019 | 09:35 AM
Dieseloholic1
That's good to know oh man that doesn't sound fun at all being cheap is not always a bad thing I just have a habit of wanting expensive ***** lol you're awesome you always help
Old Aug 2, 2019 | 09:48 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
well even being a Cheap Bastid... I avoid Junk at all costs
IF ya want High Amp starting look into Super Capacitors, they are starting to be a bit more common, I guess in a Few years they may be even cheaper.
EDIT: I can't afford it.. it has pros and cons but this will get ya started if ya want to look into it https://www.polarpower.com/wp-conten...citor_0115.pdf
Old Aug 2, 2019 | 12:45 PM
Dieseloholic1
Avoiding junk is important I'm definitely gonna check this out thank you very much
Old Aug 2, 2019 | 12:47 PM
Dieseloholic1
I bought the group 31s this morning I financed em at tractor supply they should be better than my duralast gold batteries
Old Aug 2, 2019 | 12:52 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
ya TSC has good batteries
Old Aug 3, 2019 | 07:58 AM
Dieseloholic1
I have never bought TSC batteries before I wonder how they will last/work during the winter
Old Aug 6, 2019 | 08:40 PM
Dieseloholic1
Group 31 batteries seem to fit okish for some reason one side of the hood sits a little higher any ideas
Old Aug 6, 2019 | 10:10 PM
DarkOverCast
The battery shouldn't hit the hood, but double check incase you have one of those thick battery matts. If its just the hood out of alignment then loosen the hinges at the firewall and adjust accordingly
Old Aug 6, 2019 | 10:11 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I would suggest some insulation pads on the battery terminals if they are hitting the hood.
So are you saying they are too tall ?? DarkOverCast said they fit just fine ?
OR is the problem the OEM Hood insulation ?
EDIT: you could adjust the hood up just a bit so it is even, that won't hurt anything.
Are the batteries sitting all the way down flat in the trays ?
