August Nevada BS Thread
#36
Good morning everyone
I have the next 2 days off, so I'll be helping Jimmy with the new project he has taken on for a friend of ours... another HD Trike build. Atleast least this time, Jimmy is not paying for everything, building it & then presenting a final bill to the customer. I think he learned from being screwed over from the 1st trike build.... low-life thieving @$#%*&?#%.
Anyway, it's coming along pretty good so far...
Like the 1st trike build, it came in on 2 wheels & will leave customized with 3.
#37
Okay, try this again!
Jimmy got side tracked doing a Hydrographic fender for his bike.
Here's how the process works...
Tub of approx. 90 degree water
Primer/Base coated part
Paint film cut to proper size
Gently place/float film on water
After 1 min. spray with Activator
Slowly dip & submerge entire part & gently swish around to clear away excess floating paint to create a clean area before removal
Carefully remove part
Gently rinse off part & allow to dry naturally. (Do Not towel dry) Once dry, spray with Clear Coat, dry & install part
