Expedition ... Clogged Catalytic Converters
Old Jul 30, 2019 | 08:01 AM
firedawgy's Avatar
firedawgy
So I have a 03 Expy with the Triton 5.4, bad loss of power lately. Replaced the plugs and packs, fuel filter, no luck, mechanic says bad cats. being an 03 and not worth putting too much money in it what are my options? Has anyone actually had experience gutting or straight piping the cats? Will it effect the computer and how it runs? We don't have inspections down here so thats not an issue. Thanks all
Old Jan 3, 2020 | 02:27 PM
Theboneskes's Avatar
Theboneskes
This is an old thread. But you can remove the cats on both sides, weld in pipes, and then use spark plug anti fowler's on the rear O2 sensors, drill out 2 of them, and stack the drilled ones with the non drilled ones, install your O2 sensors, and screw back into the O2 holes. They CEL light will stay off. I've done it on my 2003 Expedition without any issues.
Old Aug 6, 2024 | 05:01 PM
Bertibob's Avatar
Bertibob
4wd Low
I figure I will leave the O2 sensors as is .....they are new ..... then cap over the hole I cut in the cat's
bronco6767
Nov 12, 2016 09:46 PM
canuckjgc
Feb 26, 2010 02:40 PM
propellerhead
May 24, 2004 08:13 PM
