T89 part needed
Old Jul 28, 2019 | 05:46 PM
FMcLaughlin1188's Avatar
FMcLaughlin1188
T89 part needed
Hello everyone. I’m new here and am in desperate need of help finding a part for my t89.
The transmission has been out of my truck for almost a year and I can’t take it any more. First I had to locate a cluster gear and now there appears to be a part missing. In the attached diagram it’s number 354639-s. Thank you in advance for any help that can be offered.
Last edited by FMcLaughlin1188; Jul 28, 2019 at 06:17 PM. Reason: Incorrect information
Old Jul 28, 2019 | 08:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Please, when asking questions, list all the pertinent info. Year, series and model of your truck for example.
Your 'About Me' profile says 1964 F100, so assuming this is correct....
Are you sure this is a Warner T-89? This 3 M/T trans was an option and has a non synchromesh first gear.
The standard equipment Ford type 3.03 3 M/T is an all sychromesh trans incluing a first gear synchro.
354639-S .. Output Shaft Pilot Bearing Roller Spacer / Obsolete
1961/64 Warner T-89 3 M/T
GREEN SALES CO. in Cincinnati OH has 15 = 800-543-4959.
Old Jul 28, 2019 | 09:23 PM
FMcLaughlin1188
Sorry. I appreciate your help. It is a 1964 f-100 with a 262 and a 3 speed with t89b-148 cast into the side cover and t85c-1 in the case. My research for a cluster gear proved it to be a t89 because of the straight cut first gear. The t85 has a helical cut gear. Correct me if i am wrong. This transmission has been a nightmare for me.
Old Jul 28, 2019 | 09:33 PM
NumberDummy
Originally Posted by FMcLaughlin1188
Sorry. I appreciate your help. It is a 1964 f-100 with a 262 and a 3 speed with T89B-148 cast into the side cover and T85C-1 in the case.
My research for a cluster gear proved it to be a T89 because of the straight cut first gear. The T85 has a helical cut gear.
Correct me if i am wrong. You're not. This transmission has been a nightmare for me.
T-85 is a Warner 3 M/T with Overdrive.
I found 15 of these spacers, so this problem is solved.
Old Jul 28, 2019 | 09:39 PM
FMcLaughlin1188
Thank you again!! Your information is invaluable to me at this time. I can not wait to get this truck back on the road.
Old Aug 23, 2019 | 06:49 PM
FMcLaughlin1188
Problem not solved 😫
So I contacted green sales and they confirmed they had 15 of the spacers. I ordered one and now a few weeks later it still hadn’t arrived. I called today and they said there was a mistake and they did not have any in stock. No fault of theirs, they did attempt to call me but we’re unable to reach me. So here I sit still lost. Are there anymore sources I can try. I’m very desperate for this part!!!
Old Aug 23, 2019 | 07:51 PM
NumberDummy
This is on ebay: 354639-S36 listing says it's for tractors, I do not know if it's the same.
Old Aug 23, 2019 | 08:13 PM
62SY4's Avatar
62SY4
When I get back home later I will check my Hollander. Surely with GM, Ford, Packard and AMC using the T-89 these parts may be out there. With a Warner number if the OP still can't find one I can check with a local former rebuilder. He has a host of parts he wants to get rid of... But really wants then to go as lot.
Old Aug 23, 2019 | 08:26 PM
NumberDummy
Studebaker also used it (I have a 1959/64 Studie parts catalog), don't know about Packard.
Old Aug 23, 2019 | 08:43 PM
62SY4's Avatar
62SY4
Correct, though the T85 and T86 were much more common. I'd bet Mr. Lime handled a few of these spacers on his move from South Bend to Hope.
Old Aug 23, 2019 | 09:15 PM
62SY4's Avatar
62SY4
Sorry. Strike out on the Hollander.
Looks like you need item #11, which is listed as N/A
I won't be back to my shop until Sunday. Can check my Studebaker parts books if Bill doesn't beat me to it. Otherwise I'll have to dig to see if I have coverage for this era GM. Think AMC/Jeep used the T-89 until '66, I might have coverage there as well, same for IHC.
Old Aug 23, 2019 | 09:32 PM
NumberDummy
Don't know who Lime is or where Hope is located. I do know that the Studebaker and Packard parts remained in South Bend for many years after Studebaker stopped making cars/trucks.
Old Aug 23, 2019 | 09:40 PM
62SY4's Avatar
62SY4
Studebaker/Standard Surplus/Newman-Altman/SASCO/Studebaker International history. The surplus inventory was moved from SB to Hope Indiana by the new owner (Lime) earlier this year.
Old Aug 23, 2019 | 10:36 PM
NumberDummy
I thought that Ed Reynolds (SI) bought SASCO .. I'm not currently an SDC member, but I am a member of the website.
I knew Ed and Jon Myer when both lived here in LA LA Land.
Old Aug 24, 2019 | 07:31 AM
hiball3985's Avatar
hiball3985
Transmissions and Transfer Cases Give them a call, they had some hard to find parts for a friend of mine.
