FOrd 300 first start up problem
Old Jul 27, 2019 | 06:56 PM
Josethef100's Avatar
Josethef100
Hi, I just rebuilt my motor and I’m trying to start it for first time, it had a very large consistent backfire at first so I turned distributor 180 degrees and backfiring went away, and it was turning over good and now it’s hard for it to turn over, I suspect battery but who knows. Any help would be appreciated!
Old Jul 27, 2019 | 07:32 PM
Christmas's Avatar
Christmas
Did you time it when it started?
Old Jul 27, 2019 | 09:39 PM
farmalmta's Avatar
farmalmta
Cam timing, then distributor timing
If the engine is backfiring, things aren't set right.
The cam must be properly timed with the camshaft using a degree wheel during assembly. Then the crankshaft is turned to top dead center as marked on the damper and aligned with the marker. Then the distributor is installed so that #1 terminal is where the rotor is pointing. Also the lifters, pushrods, rockers and valves must all be the right length and settings.
Hope this helps.
Old Jul 27, 2019 | 09:48 PM
Josethef100
Update: I got it to start and stay running but a new problem has risen, it’s leaking a lot from the thermostat housing, I’m very positive that it’s correct. I put the thermostat on the housing, put the gasket over it, then bolted it on but it’s still leaking a lot
Old Jul 28, 2019 | 08:15 AM
john jamieson's Avatar
john jamieson
Ask down on the 6 cyl engine forum for more responces
Old Jul 28, 2019 | 08:37 AM
fuelsmoke1's Avatar
fuelsmoke1
On the 300 it's easy to have the thermostat slip out of position when installing the thermostat housing. It will can pinch thermostat in the gasket surface area and if you tighten enough it will crack the housing.dont ask how I know that. Lol
Any I changed after that, I used a thin layer of RTV gasket maker to adhere gasket to housing holding thermostat in place. Let it set up for 10-15 minutes before installing.
Old Aug 2, 2019 | 10:47 AM
Thunderkiss1965's Avatar
Thunderkiss1965
I'm with you on the thermostat slipping down and getting pinched. Took me more than once to learn that lesson. LoL. The 302 is the same way, as well as a couple other FoMoCo products.
123FORD
13
Feb 6, 2021 11:06 AM
Josethef100
Jul 29, 2019 01:09 PM
alexchavel
Aug 23, 2009 01:13 PM
catfishwhiskers
Nov 21, 2004 06:08 PM
Big Ol Truck
1978 - 1996 Big Bronco
Feb 23, 2004 07:56 AM
