I'm replacing my slave cylinder and to my surprise I didn't have a bolt for my bracket.
I couldn't find anything online and since I'm at work I am unable to hunt for one right now so I thought I'd ask you all to help speed up the process.
What size is the bolt for the bracket?
With the ZF5 speed, certain years they never had a bolt to retain the clip. My clip worked its way off a time or two and left the slave cylinder hanging while going down the road. That was enough of that crap so I drilled and tapped a hole in the bell housing and through the clip so mine's held on with a little 1/4" bolt.
