Good day all,
I have come across a great deal on a set of Detroit Wheel smoothies and trying to determine if these wheels would fit my stock height f100.
Wheels are 20" x 8" with 245/ 35/ 20 tires.
I've searched threads for similar questions without much luck.
The outer diameter should be fine as it is smaller than that which most people use on these trucks. They will be wider which shouldn't be a problem on the back but could be on the front. However, the backspace or offset must be known in order to determine that and you would need to take some measurements of the truck to verify.
Mine have a 4" backspace in the rear and 4.75" in the front. Plenty of room in the back, but the front is tight. I am running a larger side wall, to get closer to the original tire height. I think they are 245/50R20.
Also mine is an F250 Stock suspension.
