Trailer brake issue
Old Jul 19, 2019 | 08:38 PM
Don Schuler's Avatar
Don Schuler
Trailer brake issue
I've been down the connector thing ,dielectric ,tape on the connector all were temp fixes.the real issue as I see it now is the trucks brake controller ,when I Am coming down in speed and a exit from the highway you can watch the brake force in a bar graf some times goes blank works and goes blank again, Ford will say being the truck and trailer in so we can ck it .
Any ideas would be great F250xlt 6.2 4x4 2017
Thanks
Old Jul 20, 2019 | 02:57 PM
bldfrdblu's Avatar
bldfrdblu
Brake force bar graph?????
How do I access that??!!
Old Jul 20, 2019 | 10:10 PM
Don Schuler
Go to trailer and select the one you have connected lots of info
Old Jul 21, 2019 | 04:44 PM
bldfrdblu's Avatar
bldfrdblu
I've seen the bar graph when you squeeze the manual trailer brake levers but I guess I'll have to look at that same screen when applying for the service brake . Thank you.
Old Jul 31, 2019 | 12:34 PM
Auslander's Avatar
Auslander
I have a 2019 6.2 purchased in December that was doing something similar (but different). Went on one trip, no problems. Got the trailer inspected. Went on second trip. When towing, I would get a "trailer disconnect" warning on the instrument cluster. Noticed that the trailer brakes would surge and release. Unplug the trailer, and reconnect, it would do fine until you tested the brakes with the brake controller, in which case you would see the bar graph spike out then go flat and the alarm would go off again. Limped to where we were camping and started testing connections. Figured it was some type of ground fault. Couldn't find a thing and started having a serious case of buyer's remorse - figured I had a bad controller. Hooked a buddy's trailer up and didn't have an issue.
In the end, I pulled the emergency break-away switch and plugged it back in. Solved my problem. Apparently something did not seat properly when it was tested during inspection. Do you have access to another trailer that you could plug in to isolate whether it is an issue with the trailer or the truck?
volwing1
6.2L V8
Aug 28, 2015 03:09 PM
pineconeford
May 14, 2014 06:56 PM
KHAYES
All Things Towing
Jun 12, 2013 12:09 PM
trap4x4
Sep 15, 2010 05:13 AM
cfd312
All Things Towing
Nov 8, 2009 08:08 PM
