Sponsored by: Real Truck
what else should I do when I pull my engine?
Old Jul 15, 2019 | 09:39 AM
Seansproblems's Avatar
Seansproblems
I have a 2001 f350 flatbed and the oil pan has started seeping pretty bad. I'm pulling it and was wondering if there were any other things I should replace while its out. I plan on inspecting the rear main seal, valve cover gasket/harness, look over the turbo pedastool mounting and see if those o-rings are toast.
Any other known trouble spots I should look at while the engine is out would be great, Thank you.
Old Jul 15, 2019 | 09:48 AM
Fefanatic's Avatar
Fefanatic
Do all seals that you can. Check flywheel teeth for wear. Replace all hoses that are hard to get to. Other than that you should be GTG if the engine is solid...
Old Jul 15, 2019 | 10:17 AM
Seansproblems
Thank you, The engine runs great with 172K but leaves a puddle everywhere it goes. Just a matter of time before a driver doesn't think to check the oil on it and causes all kinds of stuff. I appreciate the help.
Old Jul 16, 2019 | 03:58 PM
SDSC4X4's Avatar
SDSC4X4
Check your frost plugs for corrosion around the edges. Remove, clean the block and replace if you find corrosion.
Also inspect the motor mounts for deterioration or cracked rubber parts. Manual? Do the clutch, throw out bearing and pressure plate.
With a turbo, I'm guessing its a diesel, but if it is a gasser, check all the exhaust manifold studs.
Old Jul 16, 2019 | 07:10 PM
Djosbun's Avatar
Djosbun
As the post above suggested, you should definitely replace the motor mounts. No easier time to do it then now. You will notice the smoothness of having new engine mounts once you have it back on the road.
— Dave
Old Jul 17, 2019 | 06:24 AM
NoelCT's Avatar
NoelCT
Originally Posted by Fefanatic
Check flywheel teeth for wear. .
If you have wear on ring gear, it will likely only be on the starter drive gear side face. The other side will still be good (unworn). Often, using a brass drift, you can tap ring gear off, turn over and reinstall. They're installed with an interference fit. Make sure it seats square to step on flywheel.
sseebart
Aug 11, 2014 06:55 PM
FUJINAMI1293
Jan 14, 2013 10:10 PM
Jeepincj7
19
Nov 10, 2012 03:37 PM
quiggs1404
Oct 29, 2011 07:51 PM
BottomFeeder
27
Sep 27, 2006 01:03 AM
