Wirring harness?
Old Oct 5, 2003 | 08:12 PM
mr4speedford's Avatar
mr4speedford
Wirring harness?
I only have the first out of two of the 57-63 parts catalogs, so could somebody look up a 292 F-100 turn signaled and not sure what else is needed wirring harness #? Thanks again so much! -4speed
Old Oct 5, 2003 | 08:20 PM
DS02F250's Avatar
DS02F250
Mr4Speed,
Try logging onto John's F-FunHundred's in Anaheim, Ca. They usually have schematics that show everything you need for each component and system. They might also have the same thing here on MotorHaven, FYI.
Good luck,
Butch n Me
Old Oct 5, 2003 | 08:59 PM
mr4speedford
Thanks Daryl, I'm really just looking for the actual part# for the harness. Jefro, decided to add a emergency flahers to it -4speed
Old Oct 6, 2003 | 06:41 PM
57_ford's Avatar
57_ford
I have the 56 57 chassis parts and accessories catalog. The only #s I can find is a switch & harness ***'y B7C 18440-A . Then you need the leaver B7C 13305-A. Their is also something called a wiring ***'y (turn signal flasher)B7C 14404-A. This is just for turn singles and as you know they changed some of the wireing for the different years. But a 4 way flasher I think is just some heavy truck add on thing that they still make today. You can get them from the auto parts store or maybe a truck stop. It has a bracket with a red **** on it and also comes with a flasher. At least this is the only way I have seen them. I have never seen a 4 way in the switch it self but I could be wrong. It would be nice to have one.
Old Oct 6, 2003 | 06:45 PM
mr4speedford
Thanks, I didn't really need that info but come to think of it that was another big concern. Basically(I had a bad choice of words in the first post) I need the part# for the underdash wirring harness. I guess I'll also need some turn signal wirring so those # do help! Thanks again guys, -4speed
