Sponsored by: Real Truck
Misfire help
Old Jul 4, 2019 | 06:46 AM
Qsland's Avatar
Qsland
Misfire help
2004 Ford F-350 v10. About a year ago had the po303 code and a code indicating a misfire on first 1000 revolutions of motor. At this time I replaced all plugs and coils. Everything was working fine. Now the same codes returned. I decided to swap a few coils and replace plug and injector. The misfire code came back. The truck runs mint with the exception of a slight misfire at start up for about 5 seconds. Power balance test is only completed with engine running so I can’t see what’s happening at initial start up. Any ideas?
Old Jul 4, 2019 | 10:06 AM
Fefanatic's Avatar
Fefanatic
If a injector was leaking down it would flood the cylinder with fuel and cause the miss you are describing. Once the engine started and the flood cleared then all cylinders would fire fine until it set again and soaked the cylinder. Do a leakdown test on the fuel system.
Old Jul 4, 2019 | 12:01 PM
FractureCritical's Avatar
FractureCritical
Did you replace the coil boots and use dielectric grease?
Old Jul 4, 2019 | 12:48 PM
Djosbun's Avatar
Djosbun
Can be a number of different things: leaking fuel injector, clogged injector, vacuum leak. You can spray some starting fluid or use propane and spray it in different areas around the intake manifold, listen for any rpm changes to find the vacuum leak.
— Dave
Old Jul 4, 2019 | 01:18 PM
leadmic's Avatar
leadmic
Check the PCV vacuum elbows between the left valve cover and the intake manifold. They tend to detartrate over time and create a big vacuum leak.
Old Jul 4, 2019 | 02:17 PM
Qsland's Avatar
Qsland
Yes. New coils with boots used and dielectric grease. I did replace the number 3 injector. But the miss came back. I was thinking the same about a leaky injector that’s why I replaced it. I will check for vacuum leaks. No lean codes however and fuel trims look great.
Mikeyg777
2004 - 2008 F150
Jan 27, 2018 08:48 PM
icantdo55
2004 - 2008 F150
Aug 25, 2017 12:14 AM
Tweetot
1997 - 2003 F150
Oct 29, 2009 05:43 PM
carone2
1983 - 2012 Ranger & B-Series
Jan 12, 2009 04:10 PM
travisblake68
Sep 20, 2005 07:37 AM
