2001 6.8 Misfire
Well, DANG - that's a lot, if that says 30 volts.
Anyone else able to do a quick check on their V10? I'd do it with my '97 Cougar (same alternator as my '01 V10), but my daughter has it right now.
You too punny
You too punny
The idea with alternators is, they have a diode matrix in them that only puts out DC voltage - it's pulsed, but still DC. And they generally peak around 15 volts. If you're getting 30 volts AC at the output, that means at least one of the diodes is shorted, and the voltage is swinging into the negative. Peak-to-peak on an AC waveform would give you around 30 volts.
I think the alternator is bad, but I just wanted someone else to check their alternator before we go spending your money
**dmax reads 29.4, so I assume the alt is good**
I'm of the opinion that one of those coils is not firing right (or maybe more than one), and the unreleased energy is feeding back into the system. I remember at last a handful of people that reported OSS/VSS errors, and misfires, and the ultimate solution was at least one coil was doing something funky.
If you have them already, it can't hurt to put them in. Make sure you use dielectric grease around the tip of the boot where it meets the insulator of the plug, and where the boot seals on the coil.
