1978 - 1996 Big Bronco
No throttle response while driving???
Old Oct 5, 2003 | 11:19 AM
Irysh's Avatar
Irysh
Question No throttle response while driving???
Hi all. I'm having a very strange problem with my baby. She starts fine, takes off with no problem. But sometimes when I'm going down the road my speed starts slowly dropping. If I give it more gas, I get no response. The RPM's don't go up, the speed doesn't go up, the sound doesn't even change. Then after a few seconds everything seems to kick back in. I've pulled the codes... there's only the normal EGR code that's been there for years. The only odd thing I can find is that when I was under the truck the other day with the key on, I discovered my O2 sensor was very hot. The truck had not been run yet that day. I'm not sure if this is normal or if it has anything to do with the other. Any help would be greatly appreciated!
Old Oct 5, 2003 | 11:22 AM
Irysh's Avatar
Irysh
Sorry, this is for an 89 5.8L with a c6.
Old Oct 5, 2003 | 02:33 PM
Seabisquit's Avatar
Seabisquit
O2
Sounds like maybe your Cat(s) may be have an obstruction. If you are running a 2 cat system it may be that your pre-cat is getting stopped up. Bring it up to temp and see if one cat feels considerably warmer than the other...and pull the codes to see if your O2 sensor is faulty.
Old Oct 5, 2003 | 04:32 PM
Irysh's Avatar
Irysh
Thanks Seabisquit. I have pulled the codes though, and I'm only getting the same old EGR code. Hopefully it's not the cat, since it was just replaced in november of last year. Is there any way of checking it without disconnecting it?
Old Oct 5, 2003 | 07:27 PM
jeep8589's Avatar
jeep8589
You need a vacuum gauge and hook it to a intake vacuum source. With the engine warm check the vacuum reading. Now run the engine to about 2500 rpms just until the the vacuum reading levels off and holds steady. You should see at least a couple of points higher with the 2500 rpm reading. If it dropped or stayed the same you have an exhaust restriction. I have headers on my 1990 351 and it jumped 5 points higher.
Old Oct 5, 2003 | 07:30 PM
TonkaTruck94's Avatar
TonkaTruck94
ya what was said before sounds like some sort of vacume leak.
Old Oct 5, 2003 | 08:49 PM
Irysh's Avatar
Irysh
Thanks all. I'll check that out.
Old Jul 13, 2011 | 01:46 PM
7.3stroker2215's Avatar
7.3stroker2215
Where should vacuum pressure be?
Where should the stock level of vacuum be, and what is best for power/mpgs?
Old Jul 13, 2011 | 03:15 PM
Kemicalburns's Avatar
Kemicalburns
wow bringing a thread back from the dead lol
vacume on a speed density setup should not be less then 17 but 19 would be best.
Old Jul 13, 2011 | 07:23 PM
fordbroncodave's Avatar
fordbroncodave
lol 8 years later. i sure hope the original poster fixed his problem
