Sponsored by: Real Truck
Doors Rattling
Old Jun 24, 2019 | 10:25 AM
Bigdukesix's Avatar
Bigdukesix
Trailering
Doors Rattling
Hello out there!
I was driving off road yesterday...nothing crazy just driving down a rough dirt road and my doors were rattling like they were going to come off the hinges. Couple of times I actually stopped, opened and closed them cause it was so loud I thought they had come open. They were not. So where should I start tightening and which parts are the usual suspects I should be checking?
Thanks in advance
2008, Super Duty Diesel 4X4, Level kit, standard tires
Old Jun 24, 2019 | 10:29 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Ext cab I'm assuming?
Old Jun 24, 2019 | 11:04 AM
Deuce40s's Avatar
Deuce40s
It's probably rattling on the door latch striker bolt. You can wrap some duct tape around it two or three times to see if the rattle goes away.
Old Jun 24, 2019 | 12:30 PM
geekwithoutacause's Avatar
geekwithoutacause
Door striker. Try loosening them and moving them inwards. Outline the old position to see if they actually move. Tap them w a hammer a little.
Next step is to buy the f150 strikers.
Old Jun 24, 2019 | 01:51 PM
gpeade's Avatar
gpeade
I have an 03 Crew Cab with the same issue on the driver's door. I have checked the latch but it doesn't move when screws are loosened. Curious to hear your solution.
Old Jun 24, 2019 | 01:56 PM
Bigdukesix's Avatar
Bigdukesix
Trailering
Not Ext cab, drivers side door actually
Old Jun 24, 2019 | 02:10 PM
Deuce40s's Avatar
Deuce40s
What's wrong with my solution?
Old Jun 25, 2019 | 12:58 AM
DieselBeast01's Avatar
DieselBeast01
My extended cab rattles like crazy, but it is because they have no B pillars. The suicide doors serve that purpose and since they aren't stationary, they tend to rattle.
Old Jun 25, 2019 | 08:28 AM
geekwithoutacause
That's what my previous truck had as well. I just lived with it. Now I have the crewcab and they still rattle.. ! You would think Ford got that figured out but. no...
Old Jun 25, 2019 | 06:00 PM
SuperDutyScaler
Silicone tube seal mod, problem fixed
Old Jun 25, 2019 | 07:37 PM
geekwithoutacause
Might work on the old style door seals, but doesn't work on the newer style.
Old Jun 27, 2019 | 10:29 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
How come? Is it that the rubber gaskets are not hollow? I would think stopping the rubber gasket from collapsing a bit would help any year?
Old Jun 27, 2019 | 10:36 AM
geekwithoutacause
They are hollow but have a 2nd outside hollow layer. They don't really collapse so adding the tubing doesn't do much. I tried on mine and it made no difference. What helps is to to move the strikers as much in as possible. Even then it won't always fix it. Tried that too, fixed one door but left 3 others still noisy. Ultimate solution is the f150 strikers that have the rubber bumper in them.
Old Jun 27, 2019 | 10:49 AM
Fefanatic's Avatar
Fefanatic
What year F150 strikers? I haven't heard of this.
Old Jun 27, 2019 | 03:28 PM
GN1220's Avatar
GN1220
Must be a newer one because I had an '05 for a bit that we flipped and those doors were terrible.
