Sponsored by: Real Truck
Testing Shocks
Old Jun 23, 2019 | 08:26 PM
Rob89's Avatar
Rob89
Testing Shocks
Hey guys. So this isn’t a rant or complaint about how Super Duty’s ride- they are heavy duty trucks built to tow and haul and have E load range tires on them, etc. which all together contributes to a harsh ride when unloaded.
All that said, I think with 37k on my 2016 F-250 that my factory shocks are about dead and was wondering if it was a bad idea to pull one to verify. I’m looking at a new set of Bilstein 5100’s for $299 from Stage 3 Motorsports and just wanted to be sure before I pulled the trigger on it.
Old Jun 23, 2019 | 11:38 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I don't see why it would be a "bad idea" to pull one to test it, that said, I don't personally think it's worth the effort. If you look at them and you see oil; they're bad. Jump on the bumper. More than one or two up/down cycles means they're bad.
The factory ones are pretty cheap, and should last longer than 37k, but under tough conditions they could wear out prematurely.
Old Jun 24, 2019 | 05:32 AM
senix's Avatar
senix
you could take a rear one loose and the axle and see how easy it is to compress.
I have 65K on my 2013 with the original shocks. No issues so I leave it alone.
Old Jun 24, 2019 | 07:07 AM
Rob89's Avatar
Rob89
I took the driver side rear shock loose from the bottom mount this morning and it is toast. I can compress it fully with my hand without using too much force. New Bilstein’s from Stage 3 Motorsports should be here by the end of the week!
Just in time for a Florida trip I have coming up. We all know how horrible I-95 in South Carolina is!
Old Jun 24, 2019 | 07:31 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Good call. The rears should be much stiffer than that. I had to use a jack to compress mine for install
Old Jun 24, 2019 | 07:34 AM
Rob89's Avatar
Rob89
Oh wow! No jack needed this morning! Although thanks for the idea for installing the new ones!
I also noticed a couple other drivability things over the past couple months besides the rougher than normal ride which also led me to believe the shocks were no longer working.
Old Jun 24, 2019 | 12:35 PM
geekwithoutacause's Avatar
geekwithoutacause
I was able to push in the rears by hand with some effort. it's more about how much resistance does it give you on a quick attempt to compress.
Mine were still good at 50k
ArcticCircle
Apr 19, 2019 02:48 PM
DieselVol
Oct 6, 2014 01:04 PM
Winstonater
Nov 19, 2010 07:24 AM
Futuresweets-10
May 28, 2009 03:58 PM
tigerdude2001
Aug 29, 2003 08:00 PM
