Recon cab light install question
Old Jun 23, 2019 | 04:57 PM
ProFam25's Avatar
ProFam25
Truck already has cab lights. Bought the Recon smoked lights and about to put them on. Honestly surprised on the build quality, comparing the lights to the stock ones and they look exactly the same. Already took the stock ones off and they came with the foam on them just the like the Recon ones but the bottom side of the stock foam was stuck to the roof. I assume they were double sided taped but the Recon lights do not have any adhesive on the bottom of their foam. Am I missing something or does Recon expect you do put some type of adhesive on or is their foam enough to stop any leaks? I don't want to go crazy with any glue or anything as I want to be able to remove them if I have any problems in the future. Have any ideas?
Also, is there a torque sec out there for the bolts holding them down?
Thanks!
Crewcabber
Jun 4, 2014 08:32 PM
No.Va.F150
2009 - 2014 F150
Jan 18, 2012 07:03 AM
patman247
May 2, 2011 11:40 AM
Shaun lindmark
Mar 13, 2010 08:05 AM
gmcmatty90
Aug 17, 2009 01:14 AM
