Dragging 4th gear help
Old Jun 22, 2019 | 12:41 AM
brandon FRANCIS's Avatar
brandon FRANCIS
Hi I have an 87 Ford F250 with a 302 5.0. Every time I shift into 4th it acts like it's dragging behind on getting up to speed. Any ideas why that might be happening I think it has the t18 or t 19 transmission it's a four-wheel drive.
Old Jun 22, 2019 | 04:31 PM
1TonBasecamp's Avatar
1TonBasecamp
Have you had the truck awhile, or did you just get it recently? Did it start acting this way all of a sudden, or has it done it all along?
What differential gear ratio do you have in the rear, and what size tires are you running?
Do you have a tachometer?
Normally with any transmission you would feel the lack of power in every gear if your tires were too big for the diff gears. But maybe your engine has enough power and the manual trans gear ratios are just enough that in the lower gears you don't notice it as much? Then, when you shift into top gear you really feel the mis-match.
What other modifications have been done? To the engine and chassis and brakes basically.
Good luck.
Paul
Old Jun 24, 2019 | 07:32 AM
brandon FRANCIS
Good luck.
Paul
Everything on it is stock for what i know. I just bought it aboit a month ago and it only bogs in 4th. the tires are stock. Could it be the transmission?
Old Jun 24, 2019 | 09:02 AM
Freightrain's Avatar
Freightrain
F250 4x4 with only 302? Ya, I bet it's a bit lazy in 4th gear, especially in town. Read the door tag and find out what axle code it has. I really doubt it has anything to do with the transmission. That 302 was not much of a powerhouse back then. Is it EFI or carb? In that time frame I think was the transition and could get either? My '89 was EFI.
mustang347gt
15
Oct 14, 2007 11:08 PM
84tealbeast
Oct 17, 2006 10:00 AM
backwoodspuller
Offroad & 4x4
27
Feb 5, 2006 10:17 AM
jvcajw
1978 - 1996 Big Bronco
Aug 7, 2004 11:39 PM
Pastmaster
Jul 21, 2000 11:13 AM
