Transmission/light/fuel gauge issues
I've got a 93 f350 w/460 heading home tonight and the left side headlight started flickering, the fuel gauge was sitting at a half tank and then jumped to way over full and then the transmission either kicked out of overdrive or just jumped up to 2100 rpms in overdrive. A little further down the road and wouldnt you know it I got pulled over and the DS taillight and DS headlight were both dim to the point you can barely see them. I have no idea what can cause all of these, except maybe a bad ground but I would think that all the headlights and taillights would dim if that was the case? Also if I shut the truck off with the key on the lights work fine.
Also the passenger side taillight is out. They're LEDs and I had issues in the past with the LEDs causing transmission problems but I installed resistors and that took care of the problem. Any help would be greatly appreciated.
jte1998
01-28-2017 06:17 PM
BigRobs99
10-31-2016 05:55 AM
