Married to it!
There's really only two major items to take care of now. One is the EXTERIOR PAINT. It was an XLT-Eddie Bauer Edition, (according to someone I know who saw it and seemed to know the clues to identify that package). Its interior has been almost completely changed out with the corresponding components from the '88 "XL" with the factory Sport package. The '84 XLT exterior color is a two-tone, black with silver from about the door handles, down. I'm thinking about making it all black, or something very close to that. As another possibility, I wonder if anyone's tried an 'evergreen forest' camouflage paint scheme. Probably too weird an idea.
The other item would be WHEELS & TIRES, since the factory alloy 15x7's are too badly weathered from the Pacific coastal environment and severe neglect. On those rims are now a set of 30x9.50 M+S truck tires. These tires are very heavy, with a Class 'C' load rating, and as a result very difficult to properly balance. Right now they JUST rub the front anti-sway bar during full-lock turns. About a 3/4" positive offset would eliminate that, without changing the wheel size. Still, it's perhaps a bit too much rubber for this size and weight vehicle.
So, I'm seriously considering reducing the amount of rubber weight by increasing the amount (i.e. diameter) of alloy wheel in order to stay close to the desired diameter of the "30's" I now have, by going to 16" or MAYBE even 17" aftermarket wheels. Fender space limits the width when a larger diameters are desired, without modifying body and/or chassis height or flaring the fenders. And tall narrow tires just don't look "right".
But, by going to 16x7's on the front and 16x8's on the rear, while carefully calculating the aspect ratios, (for instance, 225/75's on the front and 245/70's on the rear) and match their diameters as closely as possible, insuring their desired synchronicity between the front and rear axles in 4WD, I'm hoping to get greater stability and "drive-ability" at all legal speeds, on AND off dry paved roads, as well as in adverse weather conditions.
I expect matching pairs of different sizes in multi-duty tires to do ALL that will be quite a challenge and may ultimately force me to go with, at least, the same sized tires (say, 235/70's) all around, if not the wheels (16x8's), too!
If anyone out there in 'cyberland' with experience and/or knowledge on those matters feels like putting in their "5-cents" (you know; inflation), I'm all for it!
