1978 - 1996 Big Bronco
lost my overdrive ?
Old Oct 4, 2003 | 07:52 PM
toeyesblind's Avatar
toeyesblind
lost my overdrive ?
Anyone have any idea why my 1988 bronco will not shift into OD?
shift's all the way up to it, then nothing! I have a C-6 trany, not computer controled. HELP!
Old Oct 4, 2003 | 08:23 PM
Torky2's Avatar
Torky2
Um, huh? The C6 is a 3 speed auto, there is no overdrive 4th gear.
Old Oct 4, 2003 | 08:53 PM
toeyesblind
Thanks torky, I guess i'll have to wait to get vech. and see for myself what it has for a tranny? I did not pick it up yet. Thanks anyway?
1988 XLT BRONCO
6" LIFT 3" BODY
38" S.SWAMP
302 CDI AND NOT A C-6 TRANNY !!
Old Oct 4, 2003 | 09:19 PM
Torky2's Avatar
Torky2
Oh, OK. Now that you listed its engine as a 302, then it would have the AOD trans, which IS a 4 speed auto. The C6 is a bigger trans than the AOD. You can ID the AOD by its trans pan shape, it is a rectangle, but as it goes towards the back, it angles inwards a bit on both sides.
First thing to check on an AOD vehicle that won't shift into OD is the TV Cable grommet, and then the TV Cable adjustment. "TV" stands for Throttle Valve".
Movement of the Throttle (you!) causes a corresponding change in the TV Cable, which goes down to the trans. Get more on the gas, and the TV cable moves more and signals the TV Valve in the trans to increase the control pressure. This does two things:
It increases the trans shift points, the 1-2, 2-3, & 3-4 shift points all go up in speed roughly proportional to throttle opening, to hold each gear longer for better acceleration.
It also increases the pressure used to squeeze the respective clutches together in the shift. This prevents excessive slipping.
Why don't they have it high all the time for tight shifts? Because it would bang from gear to gear under lighter throttle.
That TV Cable grommet can age and fall apart, messing up the TV Cable's effective length. Really should look at a manual to do anything with a TV Cable. Wrong adjustment, or driving it with the TV Cable disconnected due to a grommet that destructed can/will cause major trans damage due to slipping clutches. The number 1 source of AOD trans problems is TV Cable related.
Have fun with your new toy
Old Oct 5, 2003 | 07:37 AM
toeyesblind
Thanks again TORKY! After some reading (you) are right about the AOD tranny and I have read up on the TV. thanks hope it is it, let you know
6" LIFT 3" BODY
38" S.SWAMP
AOD !!
