Engine/ Toploader help
Old Jun 12, 2019 | 06:41 PM
Matts56F100's Avatar
Matts56F100
Hey guys. I'm building a 56 F100, mostly from parts from anything I can find.
My question is, I have a 351c and want to put a Toploader behind it. The one I found is a HEH-J from a Galaxie. It is a close ratio. I'm just wondering on how the drivability is going be with 4:10 in the rear. I have found so many mixed comments that go completely off track from the question. It is mostly going to be driven around town and some highway. I don't want to be going 55 and red lining the engine.
Old Jun 12, 2019 | 07:14 PM
85e150's Avatar
85e150
What size tire are you running?
For example, if you are running a 235/75x15, a 29 inch tire, you will be turning 3087 RPM at 65 MPH. Not the redline, but a bit high.
Do you have the toploader yet?
Are you going to hammer on this thing?
Is your motor a fire breather?
IF:
--no trans yet,
--no hammering
--no fire breathing
THEN:
Consider T5.
Old Jun 12, 2019 | 07:20 PM
Matts56F100
Yes I do have the trans. I do not know much yet about engine internals, bought it about two weeks ago. I'm not going be out running cops on a daily base, but want it to be able to hold its own if needed.😁 I will never have it on the drag strip.
Old Jun 12, 2019 | 07:35 PM
85e150's Avatar
85e150
Well, that toploader will be fun with great gear spacing. The 4.10s will save you on start up and you'll be really glad for them when starting on a hill.
The RPMs at 65+ might serve as a governor for you!
Run it. Do you have your bell and clutch figured out?
Old Jun 12, 2019 | 07:38 PM
Matts56F100
It's in the truck just have to figure out the clutch. I was thinking going hydraulic with external slave.
Old Jun 12, 2019 | 07:50 PM
85e150's Avatar
85e150
IIRC '57 to maybe '60 have juice clutches. Master looks just like the brakes. We had a '58 F600 but I never inspected the under dash or clutch fork set up.
In the later model stuff, quoting information here: Originally Posted by NumberDummy
Only 1983 F250/350's with 460's or 6.9L's have it (and Rangers).
Everything else got it in 1984, except Econolines with the Mazda 5 speed > 1986 was the first yea
r.
Many if not all will be external slave, other than Mazda and most ZF transmissions.
Econolines used a vertical master that went through the floor via a bell crank or some other Rube Goldberg linkage under the dash.
Your pedals are under slung aren't they?
Old Jun 12, 2019 | 08:31 PM
Matts56F100
No my brake pedal is firewall mount and I was going to fabricate the clutch pedal once I found something that would work. I will be going to the pick and pull again this weekend to see what I can find.
Thanks for all the help.
Old Jun 15, 2019 | 01:09 PM
Crop Duster's Avatar
Crop Duster
I'm just wondering on how the drivability is going be with 4:10.
Folks have been driving OD transmissions for too long. The first brand new truck I ever bought was a 1972, 3/4 ton GMC with a 4.10 gear. I put over 100,000 miles on it in 3 years, mostly interstate. Never worried about how many rpms it was turning at 80mph. It only hurts the gas mileage. I have a 3.70 gear in my 65 and it turns between 26 an 2800 on the highway, it kind of likes it there and just hums along at 9 mpg. Which works out fine since at my age that puts a tank of fuel and my bladder on the same schedule.
Old Jun 22, 2019 | 11:16 AM
baddad457's Avatar
baddad457
Is that Toploader a 390 transmission ? If it is the input snout is too short to work with a small block bellhousing. It will reach to the edge of the pilot bearing/bushing but not into it, leaving the input unsupported when you engage the clutch. If you can find a longer bushing (Boss 302/Bronco) you can fix this. Otherwise you'll need a small block input shaft for it. The 390's used the small block diameter input with a shorter snout. I would look into an aftermarket hydro clutch setup for this
Old Jul 10, 2019 | 06:13 PM
77custom408's Avatar
77custom408
You want the steeper gears with a close ratio toploader it will make it feel more like a wide ratio
Old Jul 13, 2019 | 04:41 PM
baddad457's Avatar
baddad457
Define "steeper"
Old Jul 13, 2019 | 08:22 PM
Matts56F100
Thanks everyone for your help and input. After twisting my knee at work, of corse my left, I have decided to go auto. Once again, Thank You
Old Jul 14, 2019 | 02:04 PM
Crop Duster
Good choice you will be a lot happier driving it around especially in traffic.
Ford Road
Jan 12, 2018 07:53 PM
cws10190
Nov 29, 2012 02:33 PM
ImSoQuazy
Aug 25, 2011 11:31 PM
lbrauer
May 20, 2010 11:24 PM
cbass139
25
Aug 21, 2009 01:51 PM
