Help! Oil in coolant overflow
If this truck is equipped with an external oil cooler, mounted between the block and oil filter, it has engine coolant running through it to cool the oil. It's possible that it may have some sort of breach internally, allowing the oil and coolant to mix. Does the motor run fine otherwise?
How's the radiator cap look? I checked out a truck with a trans cooler breach and the ATF had swelled the seal on the rad cap so much that you could barely get it back on. I'd expect engine oil to do something similar. Any pudding on the underside of the oil fill cap?
I'll have to check under there.
Shoot.
We thinking Head Gasket?
Fluid mixing does generally suggest head gasket failure, which is why I'd check the easy stuff for that first. That said, the headgasket on a pushrod motor doesn't hold back oil pressure, so if that had gone I'd expect coolant in the oil, not oil in the coolant. That leaves a leak between the pressurized oiling system and a coolant passage (oil pressure's higher than coolant pressure), which would mean a breached cooler (if equipped) or a cracked block.
My only other thought is that somebody went to top up the oil and put it in the wrong place, though the oil in the pan looks too dark to be fresh, and also I'm guessing your friend's smarter than that.
With oil in the coolant, it can still test positive for hydrocarbons. It's a tough situation when you have oil coolers as a potential source of intrusion. Certainly could be used as a tool for diagnostics, but is not the end all be all like it would be if he were just losing coolant, or had an overpressurized system because of compression only leaking into the coolant system.
