95 F150 4X4 AODE SLIPS INTO NEUTRAL WHEN SHIFTTING FROM OD TO 3RD WHEN NOT UNDER ACCELERATION. PROBLEM SEEMED MINOR UNTIL 1450.00$ REBUILD. IT HAS BEEN BACK IN THE SHOP (3) TIMES IN LESS THAN A MONTH TWICE BEFORE IT LEFT ME ON THE SIDE OF THE HIGHWAY WHEN IT WOULD DO LONGER SHIFT INTO 3RD OR OD. TRANS SHOP HAS SUPPOSEDLY BEEN BACK THROUGH TRANS COMPLETELY REPLACING THE VALVE BODY AGAIN AND THE SPEED SENSOR. REPLACED THE MLPS MY SELF AFTER CODE (659) DETECTED . AT PRESENT COMPUTER IS THROWING NO CODES BUT CONTINUES TO SLIP INTO NEUTRAL. TRANS SHOP SAYS NOTHING MECHANICALLY WRONG WITH UNIT MUST BE SENSOR BASED SUGGESTED A TRIP TO THE DEALER AT MY EXPENSE. HELP!!!!!!!!!!!!!
COMMON I NEED SOME HELP WITH THIS PROBLEM. I HAVE REPLACED THE MLPS AND THE DIFFERENTIAL SPEED SENSOR
SINCE MY LAST POST TO NO AVAIL. STILL NO TROUBLE CODES SET IN COMPUTER MEMORY ON KOEO OR KOER TEST NOTHING IN CONTINOUS MEM ALL I GET IS CODE 111.
I personally can't help you but try this other board. it is the thunderbird and couger club. They have some very knowlegable people on there. One of the fellows was involved with the disign of the aode. http://forums.tccoa.com/index.php?s=
Go down to the driveline area and post your question and I promise you'll get some answers
Clint
THANKS FOR TAKING THE TIME TO RESPOND TO MY REQUEST FOR HELP THE LINK HAS BEEN VERY HELPFUL IN GIVING ME SOME IDEA AS TO WHAT TO CHECK NEXT . I HAVEN'T POSTED ON THAT SITE YET BUT FROM WHAT I HAVE READ I BELIEVE SOMEONE MAY BE ABLE TO HELP.
