Cross Country with the 300 I6
Hey all, long story short I need my truck, which in Phoenix, AZ but unfortunately I am in Parris Island, SC right now. So to fix this dilemma I'm trying to gear up for a cross country trip in this speed machine but I have a concern. The truck itself is an 88 F-150, 130k miles, 4x4 long bed single cab, and a 4.9L I6 with the T-18 4spd. No mods outside of some 32" all terrains and some professionally-done body damage. So my worry here is how safe is it for the Ford 300 to turn at interstate speeds without overdrive?
Last year I took it about 200 miles at 75mph, including through some mountain ranges, and so long as I ignored the crippling depression that came with the cost of gas, the truck did great. But that was 200 miles and this is 2,100 miles. There's no tach but if you could translate a 4.9L's RPM noise into English, it was undoubtedly cussing me out every time I went above 65. So what are yall's thoughts? Are these straight 6's safe to hold those RPMs for that long or am I just being paranoid?
Regarding the tach, I'm probably just going to buy a cluster with a tach on it, from what I've read that should be a plug and play job anyways and they go for cheap on ebay
In my line of work, not showing up on a Monday morning can turn into a nasty legal ordeal so that definitely makes me feel better about this trip
4th gear in t18 is direct drive (1:1). 32" tire drags down rpm over stock 29" tires. There's no slippage in the system, so calculations are pretty straightforward.
65 mph is 5720' per minute. 32" tire has a circumference of 8.38', so need 683 revolutions per minute to go 65mph (divide 5720' by 8.38'). Then multiply gear ratio by wheel RPM to determine engine RPM (engine spins faster than wheels).
E.g., 2.73:1 axle gear would be: 2.73 × 683 = 1865 engine RPM
2.73=1865 RPM
3.08=2104 RPM
3.31=2261 RPM
3.55=2425 RPM
3.73=2548 RPM
4.10=2800 RPM
Mudsport is correct. Deviations from these values lie partly in tachometer and speedometer accuracy but mostly in tire size variations. By that I mean that a manufacturer's claimed 32" tire is often smaller, so you'll see a little higher engine speed, but not much.
2.73=1865 RPM
3.08=2104 RPM
3.31=2261 RPM
3.55=2425 RPM
3.73=2548 RPM
4.10=2800 RPM
I'd just change the oil and maybe the coolant, top off the fluids, check the tires (including the spare!) and hit the road. I would keep some extra fluids (brake fluid, oil, and coolant) and a set of jumper cables in the truck. Maybe a roll of duct tape and some zip ties too. Enjoy the ride and have fun. I'd love to be able to take my truck on a long trip.
I agree with this. I put almost 300K miles on my 302 / C6 / 3.55 equipped ‘87 Bronco. It would run all day long @ 3000 rpm on the highway. The only issue I had was the gas gauge dropping toward “E” rather quickly.
But overall I'm feeling pretty good about this now. It's been about a year since I last drove it so all the fluids and the battery are being changed anyways. Clutch is new, clutch and brake hydraulics are new, and the T-case is "new" from a low mileage junkyard truck, drained and filled the transmission and rear/front end when I swapped that out. Tires have less than 500 miles on them. I'm gonna book the flight tomorrow, I've gotten enough "go aheads" to put me at ease lol
But overall I'm feeling pretty good about this now. It's been about a year since I last drove it so all the fluids and the battery are being changed anyways. Clutch is new, clutch and brake hydraulics are new, and the T-case is "new" from a low mileage junkyard truck, drained and filled the transmission and rear/front end when I swapped that out. Tires have less than 500 miles on them. I'm gonna book the flight tomorrow, I've gotten enough "go aheads" to put me at ease lol, I just wanted to get some input, my work is not the most forgiving when it comes to situations that make me late
I believe the OP was worried about engine speed while driving cross country because of the lack of overdrive.
