Service Engine soon
Old Jun 6, 2019 | 09:37 PM
toddoxley's Avatar
toddoxley
Service Engine soon
I recently replaced the positive battery cable in my 1999 7.3. Completely disconnected both battery’s and when I reconnected everything back the service engine soonlight was illuminated. Any help is greatly appreciated.
Old Jun 7, 2019 | 07:32 AM
Colorado350's Avatar
Colorado350
Welcome to FTE.
Try disconnecting both batteries, leaving them off for 20 minutes, then reconnect them.
Old Jun 7, 2019 | 08:03 AM
Brother Les's Avatar
Brother Les
Sometimes a code is tripped that will then reset itself and the CES light will come on and go off a short time later when driving around. The light most likely will go off in a short amount of time and everything will be fine. The code should be 'stored', but it should mean nothing.
If it stays on for a long time, touch back with us.
Old Jun 7, 2019 | 12:58 PM
toddoxley's Avatar
toddoxley
Thank you for your help
Old Jun 7, 2019 | 01:12 PM
Brother Les
We could and usually suggest to 'pull the code(s)', but a standard OBDII will not work with these trucks.
There are scan tools that can be used.
I have a 'SuperChip' installer and it is able to pull the 7.3 codes.
you should be fine.
toddoxley
Jun 7, 2019 12:58 PM
buddythomashou
Oct 22, 2005 09:03 PM
dr worm
Sep 11, 2004 11:39 AM
esiemer
1997 - 2003 F150
Apr 2, 2004 08:24 PM
jclee1014
1997 - 2003 F150
Mar 31, 2004 10:28 AM
