It's Alive
Old Oct 4, 2003 | 12:09 PM
S'CrewLoose's Avatar
S'CrewLoose
It's Alive
Cut out most of the old frayed wires and gave it a crank.....
http://users.rcn.com/tncpa/dec/53clip.WMV
Old Oct 4, 2003 | 12:26 PM
56efffie's Avatar
56efffie
Congrats,
I love the sound of those ol' Flatty's
Old Oct 4, 2003 | 01:28 PM
mr4speedford's Avatar
mr4speedford
Ooohhhh, that flatie sounds as good if not better than my Y-block! It's always sweet when you get these things running after a long nap -4speed
Old Oct 5, 2003 | 08:01 PM
S'CrewLoose
Soldered the radiator and filled it with fluid today........let it run enough to circulate the fluid from the rad to the block and back. When i went to restart it, it began to crank then just stopped. At first i thought it was siezed.....I took a wrench to the crank and it was free, now i'm thinking i fried the solinoid cranking it? any therories?
Old Oct 6, 2003 | 08:36 AM
Earl's Avatar
Earl
Could be:
1. battery
2. battery cable
3. solenoid
4. starter motor cable
5. any of the grounding cables
6. starter-to-bell housing flanges aren't providing a good ground
7. ignition switch
8. wires to/from ignition switch
To find out which, check for voltage across the starter input terminal and case with the ignition switch in the start position. Got voltage - your starter is fried. Work your way back to the battery.
