Front differential noise
Old Jun 5, 2019 | 09:28 AM
Wydaho414's Avatar
Wydaho414
I’ve got a 19 f350 dually. When I’m in 4 x 4 and I let off the accelerator the front diff makes a pretty loud noise. Best way I can describe it is maybe a bearing noise. Dealership replaced some/all, I’m not sure, of the gears in the diff. This made no difference in the noise. Anyone have any ideas what it could be?
Old Jun 5, 2019 | 10:18 AM
D3thM3tal's Avatar
D3thM3tal
That is dealership work, they should probably run it on the lift to reproduce the noise.
Old Jun 5, 2019 | 10:38 AM
Sport45's Avatar
Sport45
What were the conditions when you let off the throttle? How fast and were you in mud, sand, on ice, etc...
Old Jun 5, 2019 | 11:59 AM
BillyE's Avatar
BillyE
The transfer case isn’t dead silent either. It’s hard to say if it’s normal or not without hearing it.
Old Jun 6, 2019 | 01:43 PM
adgjqetuo's Avatar
adgjqetuo
Mine does the same thing - I was told it's "Normal".
I didn't trust the dealer's word so I took a couple trucks out and tested them and sure enough they both made the same noise as mine - one was even louder.
Coincidence? Not sure, but it made me feel a little better about it.
Old Jun 7, 2019 | 10:49 AM
Fr8dog69's Avatar
Fr8dog69
I noticed my front diff making noise last winter in 4wd high driving through snow etc. barely noticeable. Btw my Dana M300 rear makes more noise.
Old Jun 8, 2019 | 09:11 AM
Wydaho414's Avatar
Wydaho414
I’ve noticed it on snow covered roads, gravel roads and dry paved roads. Speed doesn’t seem to matter. The noise is present at 55 mph and 20 mph. Though it is louder the faster the truck is moving.
Old Jun 8, 2019 | 09:29 AM
Sport45's Avatar
Sport45
The noise may be a result of binding in the driveline. Of those three conditions only the snow covered road may allow enough slip to prevent things from winding up on you.
When you put a good load on gears you can expect them to make noise. And you'll hear it more during a torque reversal such as letting off the throttle.
Wydaho414
Jul 12, 2019 08:05 AM
jermort
6.7L Power Stroke Diesel
104
Jan 6, 2017 10:45 AM
FUJINAMI1293
Jul 17, 2012 11:04 PM
caprang
6.4L Power Stroke Diesel
Jun 23, 2011 11:51 AM
