Dim tail light
Old Jun 2, 2019 | 01:44 PM
Googs81's Avatar
Googs81
Dim tail light
I've got a 1964 f100, and the left tail light is much dimmer than the right one. I changed the bulb and it didn't help. Any advice on where to start?
Old Jun 2, 2019 | 02:22 PM
cosmofennema's Avatar
cosmofennema
Check voltage. Check ground continuity. Check all connectors. Clean everything.
That should do it.
Cosmo
Old Jun 2, 2019 | 05:02 PM
BobbyFord's Avatar
BobbyFord
Check for solid ground.
Old Jun 3, 2019 | 06:59 AM
robertrpeak's Avatar
robertrpeak
Have the wires been cut? If so they may be hooked up incorrect.When you put the brakes on is the brake light on the "right" dimmer than the left? Which filament is lighting when the lights are on, the short or tall one? Should be the short for running lights and tall for brakes.
Old Jun 16, 2019 | 04:21 PM
Googs81's Avatar
Googs81
Success!
The bolts and washers that attach the bracket that holds the taillight to the bed were rusty and corroded. Cleaned the bolts and washers
and put on new nuts so the ground is solid and lights work perfectly.
BettyBlue_96_PSD
Aug 2, 2015 10:08 AM
ironheadchopper
Oct 18, 2011 08:40 PM
whereeaglesdare83
Sep 27, 2010 09:23 PM
furyus
Oct 20, 2009 12:07 AM
3rdshiftzombie
Electrical Systems/Wiring
Mar 26, 2006 01:51 PM
