Grandpa's Truck F250 Supercab Camper Special Ranger XLT
#33
So, the dash is a flat black, i wanted to the glove box to look original... it had so.e bad scratches on it. I've tried painting it, wet sanding it than flat clear. I just couldn't get it to match correctly. So, I bought so.e flat black vinyl. I thinks it turned out ok. It matches perfectly when I sat it in there for a test fit.
#34
#35
#36
#38
So, I got it registered yesterday... Yahoooo! Drove it the tire shop and had the new tires on. It was running great, until it wasn't!... As I was driving it back home I stopped for fuel, I didn't get more than 100 yards from the gas station when it started acting like it was choking out and it wasn't getting any fuel. It stalled out. My dad showed up in his fancy brand new Dodge Dually to tow me back to the house. I did some trouble shooting, checked my inline filters first, they were ok, pulled the hose off of the inlet of the carb, cranked it to see if the pump was working, it was. I re-connected the line to the carb. Now to check the jets in the carb. I was using my self triggering tether switch, that is when I noticed that hole on the front of the carb was shooting fuel onto the manifold. Somehow, that factory plug had came out. Well... It gets better. The very second the fuel hit the hot manifold... Boom.... We have fire! Me and my father scrambled for the garage, than I realized. There's a fire extinguisher in my Jeep. BAM! fire out. No damage whatsoever. It's safe say, now the truck has one too. Phew... That was close, My dad even managed to get it on video.
So, my question is this? How did that plug come out? I have no idea. Later today during my lunch I am going to take a look to see if that plug is laying on the manifold somewhere. What should I use to re-seat it? If I can find it.
You can see in this picture, it looks like it had been hit by something... But what? My thought is, when I was driving the air cleaner was somewhat holding that plug in place maybe... I really don't know. There's a visible gouge right by the plug. Stumps me as to how this happened.
#39
#40
#41
#42
I agree, I wouldn't trust a plug in there again. I do like the idea of tapping and threading a bolt in. I am a machinist. I can definitely figure something out. I'll take my calipers with me when head over during my lunch and see what size that is. I have a ton of taps here at work. Just from a glance, it looks like 9.5 to 10mm
#43
Looking at some of the other carb images on google, I see that even a 2150, has a similar (pressed in) plug in the top of the bowl.
It looks like from 2 different images of the 2150, I can see that there is a certain linkage that goes on some models and it goes into the hole.
SO... looks like yours could be closed off and forgotten,
Good luck!
Good luck!
#44
Good luck!
Good luck!
