Sponsored by: Real Truck
vibration
Old May 31, 2019 | 06:51 PM
dybeepvw's Avatar
dybeepvw
vibration
Changed out carrier bearing and both U joints on rear driveshaft--they were original at 203,000 miles and was still running very smooth down the road except for a bumping noise when you leave from a stop sign or red light,(worn out carrier bearing), and replaced the transmission mount also. Now have a vibration in driveline from 40 - 55 mph when empty; when bed is loaded down with 2 or 3 thousand lbs. it doesn't do it. Put new tires and balanced them still no difference; wondering if you can get a bad carrier or bad u joint new in box. It is 2000 F250 crew cab 4x4 with V10 Lariat.
drtyhatch
May 26, 2012 04:15 PM
CrazyMiracleMan
1983 - 2012 Ranger & B-Series
19
Dec 15, 2011 11:30 PM
BENG0924
Sep 6, 2008 01:46 PM
99turbo
Feb 24, 2005 10:50 PM
kwing
Jul 18, 2001 05:48 PM
