Cam duration vs head flow?
Old May 28, 2019 | 06:57 PM
jade79's Avatar
jade79
Hello,
A lot of performance cams back in the day were designed with more duration on the exhaust side to benefit factory heads that flowed poorly through the exhaust. My question is, with modern aftermarket heads flowing within 70-80% of the intake, at which point is it desirable to run a cam with intake and exhaust duration figures much tighter, or even single pattern cams? Is there a formula or rule of thumb to go by? Thanks.
Old Jun 2, 2019 | 07:07 PM
jimbbski's Avatar
jimbbski
I think the answer to your question is in your post. "Back in the day" when good HiPo heads for a Ford were rare, engine builders figured out that they could extract some extra power by doing what you described above.
The HiPo heads for the Windsor engine, both Fords and the aftermarkets are all designed to correct the exhaust flow so why use a cam designed for a cylinder head that your not using?
Old Jun 5, 2019 | 07:12 PM
baddad457's Avatar
baddad457
It's never a bad thing to add more lift and duration to the exhaust side, it helps the engine pump the gasses out, easing the HP lost in pumping them.
Akley88
6.2L V8
Jun 7, 2019 06:25 PM
gman97005
Mar 24, 2014 02:17 PM
monkei
1978 - 1996 Big Bronco
17
Aug 31, 2004 07:21 PM
phantom429
Aug 20, 2002 11:11 PM
jwtaylor
Aug 6, 2002 06:29 PM
