Towing
Old May 26, 2019 | 09:27 PM
billt28's Avatar
billt28
Towing
03 F250 SD 5.4/manual trans. Truck is lifted with 17 inch tires. Stock suspension. Thinking of buying a 5th wheel travel trailer, probably a 30’ or under. I was thinking of installing rails and using a standard 5th wheel hitch, and upgrading to an Anderson hitch later. Ami missing anything?
Old May 27, 2019 | 05:10 AM
scraprat's Avatar
scraprat
Top Answer: 5
If you don't get crazy with a heavy 5th wheel you should be ok. Depending on your lift you might have to raise the trailer some.
Old May 27, 2019 | 05:19 AM
senix's Avatar
senix
I would go straight to an under bed rail system and to the Anderson. You will need all the weight savings you can get.
Old May 27, 2019 | 08:08 AM
Army RET's Avatar
Army RET
A 30' fifth is likely to approach 10K pounds.
As shown above - you don't have enough truck.
Your truck is suited for pulling a 24' (5k) bumper mount.
Old May 27, 2019 | 10:20 AM
mwheue's Avatar
mwheue
Read this: https://blog.campingworld.com/rv-bas...-pickup-truck/
Old May 27, 2019 | 03:05 PM
billt28's Avatar
billt28
Thanks for the info.
Old May 27, 2019 | 09:37 PM
'65Ford's Avatar
'65Ford
Yep, watch the payload and tow rating...pretty cut and dry.
Remember to go through the truck bumper to bumper checking suspension, brakes, rust, etc. At 16 years it needs new brake hoses (if they're original) regardless of miles.
Old May 28, 2019 | 10:21 PM
Wes444's Avatar
Wes444
Didn't see mention of yours being 2wd vs 4wd, but with my 4wd i had to "flip" axels on our last 5th wheel to clear the bed, and I'm not lifted. Current 5th height was fine. May have to lose your lift, just be prepared for that possibility
Old Jun 2, 2019 | 05:49 PM
billt28's Avatar
billt28
It’s 4W. I plan on buying one that has the axles already flipped.
spudgi
Apr 19, 2016 08:52 PM
sudsmcduff
Mar 31, 2016 11:50 PM
dvw20748
2009 - 2014 F150
36
Nov 3, 2012 09:50 AM
Edmo
All Things Towing
Mar 30, 2007 02:21 PM
1 Black Beast!
All Things Towing
Apr 13, 2004 01:59 PM
