Sponsored by: Real Truck
AC fan not blowing
Old May 26, 2019 | 05:41 PM
deckeric87's Avatar
deckeric87
AC fan not blowing
I have had my 08 6.4 F250 for a few years now. What has recently started happening is the blower is not "blowing". I can set the fan speed and the compressor will cool the air that is coming through the vents. However the blower turns on more times then not and what ever speed I set it to it stays at. So it seems the hotter it gets the more likly the blower is to act up. is this the fan module, blower or the motor resistor?
Old May 26, 2019 | 07:24 PM
projectSHO89's Avatar
projectSHO89
Manual or automatic climate control?
Old May 26, 2019 | 07:40 PM
deckeric87's Avatar
deckeric87
In both modes. I can set temp in auto mode and change fan speed in manual. Fan will turn on after some time or when truck is cold.
Old May 26, 2019 | 08:48 PM
projectSHO89
You have an "automatic" climate control system.
Could be any of the following: Blower, blower motor control module, blower relay, fuse F24 (under hood), EATC module, wiring/connections. There is no "motor resistor" on an EATC system.
You could go through and inspect/reseat every connection and you might get lucky finding that you had an intermittent connection. Other than that, it's going to take patience and troubleshooting to find where the circuit is opening up.
Old May 26, 2019 | 09:50 PM
deckeric87's Avatar
deckeric87
thanks. Well so much for easy fix
Old May 27, 2019 | 11:11 AM
deckeric87's Avatar
deckeric87
Since the fan not working is random I have noticed if I leave the ac(and fan) on when I turn the truck off it is less likely to work when I tun truck on. Does lead to a certain part more?
Old May 27, 2019 | 12:32 PM
projectSHO89
Unfortunately, not really.
If you have a meter or test light and some patience, we can probably narrow it down.
Guth0927
May 24, 2018 06:50 PM
f-1501988
2009 - 2014 F150
Jun 19, 2014 09:43 AM
snoschu
Sep 2, 2009 07:55 PM
docdonnyb
Mar 10, 2006 06:45 PM
Yellowbear
1978 - 1996 Big Bronco
Aug 15, 2005 10:25 PM
