Just bought my first F-150 (2015) Help with info
So I just picked up a 2015 F150 and am getting conflicting info on the interwebs about my options, axle ratio and such. I'll attach a picture of the door sticker and maybe someone can tell me what the hell I just bought!
I'm a Ford guy, work rig is a 2017 F-450 V10. Just sold my 2006 F-350 DRW 6.0, before that a 2002 F250 7.3, before that a 1997 F-250 5.4 (light duty).
We just downsized from a 4k truck camper to a 21' TT and also have a light 20' aluminum boat, so an F-150 is gonna get it done and drives WAY nicer than a Super Duty.
Truck 2015 4X4 5.0 XLT with 60k with all the options I was interested in. Flowmaster exhaust (a tiny bit too loud, sounds good though) a level (but still a little rake), ridiculous wheels and tires i'm trying to like, wife loves 'em, Husky floor mats, backup camera, tinted front windows, bucket seats, Ford spray in bedliner, down hill assist, just basically super clean runs and drives super nice, like it a lot, price was good for around here (Mid $20's). I'll drive it about 4k miles a year, plan on keeping it a while.
Curious if I have the big fuel tank? I think I do, still 3/4 tank and runnin around a lot. Axle ratio? Not sure. Anything useful anyone can add I would appreciate it. I know it's a canuck truck, was from Vancouver area just north of me, so not a salty mid west or oil rig I do know. Also, XTR package, just some chrome handles and to hooks I think, looks decent for this granndpa, not too much chrome on the truck.
Truck 2015 4X4 5.0 XLT with 60k with all the options I was interested in. Flowmaster exhaust (a tiny bit too loud, sounds good though) a level (but still a little rake), ridiculous wheels and tires i'm trying to like, wife loves 'em, just basically super clean runs and drives super nice, like it a lot, price was good for around here (Mid $20's). I'll drive it about 4k miles a year, plan on keeping it a while.
As far as your tank capacity, just multiply your current MPG‘s by what you said you have remaining which is 3/4 of a tank.
It won’t be 100% accurate but you’ll get an idea on if you have the 36 gallon tank or the smaller one.
You can probably get a VIN decode to figure out what the rear ratio is. Another way is to just run 60 MPH in high gear and calculate what the ratio is from the RPMs.
When you fill up the tank at the gas station, the 36 gallon tank will give you a mileage to empty around 700 miles. The standard tank will be closer to 450 mile.
You have a 3.73 electronic locking.
Axle Ratio Chart
Axle Ratio Chart
- 15: 3.15 ratio, open differential
- 27: 3.31 ratio, open differential
- 19: 3.55 ratio, open differential
- 26: 3.73 ratio, open differential
- H9: 3.55 ratio, limited-slip differential
- B6: 3.73 ratio, limited-slip differential
- L5: 3.15 ratio, electronic locking differential
- L3: 3.31 ratio, electronic locking differential
- L9: 3.55 ratio, electronic locking differential
- L6: 3.73 ratio, electronic locking differential
- L4: 4.10 ratio, electronic locking differential
Thanks for the responses so far. 3.73 electronic locking diff?? Not what I see often from the little research I have done on newer F150's. I imagine it's great for towing, which is what i'll be doing most of the time besides beer runs. I have tow mirrors also, which I LOVE and are the same as on my 2017 F450, great mirrors. I didn't see tow mirrors on many F150's I looked at, if any. Is it possible I have some sort of tow package that's not standard?
Originally Posted by HVBoM for 1FTEW1EF7FFB52256
Vehicle Highlights for 1FTEW1EF7FFB52256
Vehicle Description: FORD F-150 SUPER CREW STYLESI
Model Year: 2015Vehicle Model/Type: W1E
Production Date: 21-MAY-2015Exterior Paint Code: UH
Tu-Tone Paint Code:Interior Trim Code: UG
Gross Vehicle Weight: 07000Wheel Base: 145
Components for 1FTEW1EF7FFB52256
AXLE
AXLE FRONT FWD 1:S907A
AXLE FRONT FWD 2:S993F
AXLE FRONT RWD 1:
AXLE FRONT RWD 2:
AXLE REAR FWD 1:
AXLE REAR FWD 2:
AXLE REAR RWD:
INSTRUMENT
INSTRUMENT CLUSTER 1:FL3T10849BVH
INSTRUMENT CLUSTER 2:
INSTRUMENT CLUSTER 3:
CHARGING
ALTERNATOR ID:FL3T10300KA
STEERING
STEERING ASSEMBLY:FL343C529AG
STEERING PITMAN:
STEERING SHAFT:FL343E751AF
COOLING
COOL RADIATOR ID:HL348005AA
COOL HOSE UP ID:FL348B274CC
COOL HOSE LOW ID:FL348B273CB
SUSPENSION
SUSPENSION SPRING CODE:
SUSPENSION SPRING ID FRONT:FL345310SAA
SUSPENSION SPRING ID REAR:FL345560CG
SUSPENSION AUXILLARY REAR:
DSO
SPEC DIST CD:B7
TRANSMISSION
TRANSMISSION ID:FL3P7000BA
EMISSION
EMISSION CALIBRATION:FFC1150N
EMISSION PROC ID:PFL3A12A650CXA
WHEEL
WHEEL COVER ID 1:FL341A096GA
WHEEL COVER ID 2:
WHEEL COVER ID 3:
WHEEL SPARE:FL341K003LDA
WHEEL ROAD:FL341B001JXA
ENGINE
ENGINE TAG ID:FA340AA
DRIVE LINE
DRIVING SHAFT REAR ID:FL344602LA
DRIVING SHAFT FRONT ID:
DRIVING SHAFT COUPLING:
BUMPER
FRONT BUMPER:
REAR BUMPER:FL3417775HLSMAS
GRILLE
GRILLE 1:FL348200EBSMAS
GRILLE 2:
GRILLE 3:
TRAN CASE
TRAN CASE ID:FL347A195AD
MIRROR
MIRROR 1:FL3417683ABF5YGY
MIRROR 2:FL3417682ABF5YGY
FUEL
FUEL TANK 1:FL349K007FH
FUEL TANK 2:
FUEL SEND MID ID 1:
FUEL SEND MID ID 2:
FUEL SEND MID ID 3:
WIRING
WIRING ENTITY 1:FL3T14401AGG
WIRING ENTITY 2:FL3T14405DLG
WIRING ENTITY 3:FL3T14630CG
WIRING ENTITY 4:FL3T14631EG
WIRING ENTITY 5:FL3T14632EH
WIRING ENTITY 6:FL3T14633EG
WIRING ENTITY 7:FL3T15525DE
WIRING ENTITY 8:FL3T12A581ANH
WIRING ENTITY 9:FL3T13A409FG
WIRING ENTITY 10:FL3T14A005JNE
WIRING ENTITY 11:
WIRING ENTITY 12:
AXLE
AXLE FRONT RWD 1:
AXLE FRONT RWD 2:
AXLE REAR FWD 1:
AXLE REAR FWD 2:
AXLE REAR RWD:
INSTRUMENT
CHARGING
STEERING
STEERING PITMAN:
COOLING
SUSPENSION
DSO
SPEC DIST CD:B7
TRANSMISSION
EMISSION
WHEEL
WHEEL COVER ID 2:
WHEEL COVER ID 3:
ENGINE
DRIVE LINE
BUMPER
FRONT BUMPER:
GRILLE
GRILLE 2:
GRILLE 3:
TRAN CASE
MIRROR
FUEL
FUEL TANK 2:
FUEL SEND MID ID 1:
FUEL SEND MID ID 2:
FUEL SEND MID ID 3:
WIRING
WIRING ENTITY 11:
WIRING ENTITY 12:
Originally Posted by Vehicle Information for 1FTEW1EF7FFB52256
VEHICLE DESCRIPTION: 2015 F-150 Version/Series: 150 SERIES PAINT COLOR: Tuxedo Black Metallic
BODY STYLE: Crew Cab Drive Type: 4 WHL L/H PART TIME DRIVE PAINT CODE: UH
ENGINE: MOD 5.0L-4V DOHC SEFI NA AXLE RATIO: 3.73 Ratio GROSS VEHICLE WEIGHT: 7000 LB. GVW
ENGINE CALIBRATION: FFC1150N AXLE CODE: L6 RADIO:
TRANSMISSION: 6 Speed Automatic Trans (6R80) WHEEL SIZE: 18 X 7.5" Chrome Wheel SYNC VERSION: V4 Gen1
FUEL TYPE: Flex Fuel TIRE: LT275/65R 18C A-T OWL VHR ACTIVATED: N
SOLD TO FLEET: NO RETAIL SALES TYPE: R MODEM:
This vehicle has a May 21st, 2015 build date with a warranty start date (or in-service date) of December 21st, 2015. It is interesting that this vehicle was optioned originally with LT275/65R18 tires, hence why the tire pressures indicated on the door tag are 39psi as opposed to 35psi for standard 'P' rated tires. As for your fuel tank size, HVBoM lists Ford part number KL3Z-9002-C as the correct fuel tank your truck is equipped with, which from my reading is a 36 gallon capacity. You may want to verify that information with your local dealership parts department.
Ordered this when I first got it, just got it today. Didn’t know I had the FX4 package. Can’t believe the Xtr gets the sticker instead! I paid just under half of MSRP, not bad from a big dealer with safety inspection and warranty. I guess this price is canuck though, so a little higher i guess.
sunogbahay
10-20-2016 12:53 PM
Packard V8
10-27-2009 06:20 PM
