Sponsored by: Real Truck
Hidden 7.3 overheating issue?
Old May 24, 2019 | 10:13 PM
RenoHuskerDu's Avatar
RenoHuskerDu
The 7.3 has a new fan clutch, a year old. The water pump is new. The thermostat and its housing are new. The radiator is a year old. She's tuned to about 450hp, so generates some more heat, OK. But I don't use all that power much. No speeding tickets. Just a little fun every now and then. Maybe smoke a Beto sticker import guy. So my driving doesn't generate extra heat. Mostly I cruise gentle.
Still, why do I hear the fan clutch close so often in warm weather? Even around 80F, I can hear it cycling once the truck's fully warm. And if towing about a 1.5 ton trailer, the fan will even run on the freeway at 75 mph. Not continuously, but a lot, every uphill grade, there it is, loud.
The engine temp needle never budges. But I don't trust it. Unfortunately, I can't get a coolant temp PID on the Edge console. Oil temps run around 200F when running at speed on a warm day. I run T6 full synthetic. Intake air temps are around 85F today, with S&B intake. ATF hovers round 185F but will creep towards 190 on a hot day, highest seen is 205 up our steep dirt road pulling 8k trailer.
Am I being paranoid? I don't want to overheat a good forged-rod 7.3 that has a lot of care into it. I watch that engine temp gauge like a hawk. I run Rotella ELC coolant.
When the clutch closes, it's because its thermocoupler reaches a certain temperature, right? So if my radiator were unable to shed sufficient engine heat, the clutch would not necessarily close, would it, and I'd see the temp gauge go up. On the other hand, if my radiator is doing a good job of radiating heat, then the fan clutch would actually heat up quicker, and close, and spin the fan. Am I overthinking this?
What do you guys with 7.3s hear from your cooling fan?
Old May 25, 2019 | 01:29 AM
thx997303's Avatar
thx997303
Temp gauge wont move until you're overheated, they are basically a dummy light with a needle.
Old May 25, 2019 | 06:21 AM
RenoHuskerDu
My view exactly. Ford treats us like idiots when it comes to gauges. That's why I like my Edge console.
kjnstl
16
Aug 9, 2012 10:40 PM
redmt77
Apr 1, 2009 08:36 PM
JimTZ
Oct 26, 2007 03:21 PM
-jeremy
Jul 21, 2005 01:42 PM
broncoray
Bronco II
Dec 11, 2003 03:19 PM
