Cataclean?
Old May 24, 2019 | 09:29 PM
bradleyheathhays's Avatar
bradleyheathhays
Cataclean?
2011 Crown Vic here with 305k miles, and today my engine light comes on. Scan at the local Advanced comes up with 4 codes on the cat converter. Guy says I need to get something called Cataclean and run it through the gas tank to correct the problem.
Is it worth doing this...will it make the engine run better or get better gas mileage?
Should I use Cataclean or some other product to get this done?
Old May 25, 2019 | 07:03 AM
tjc transport's Avatar
tjc transport
i ain't rite
my opinion is: snake oil.
if the cats are clogged or bad, nothing is going to magically clean them except replacing them .
Old Jun 3, 2019 | 02:02 AM
bradleyheathhays
Thanks for the info and sorry it took so long to get back. The check engine light went off but it came back on yesterday so I got the codes read again. Guy's machine read 4 codes but said they were all the same code...P0430.
I'm game for the lacquer thinner option I've been hearing about. I see low voc lacquer thinner for sale. Wonder if it matters which version you use?
cjben
13
Aug 17, 2008 08:46 PM
vfrpilot
New Member Introductions
Apr 24, 2008 04:20 PM
Mustang69
Jul 13, 2007 09:45 AM
66 Ranger
Oct 21, 2002 07:47 AM
