TPMS Relearn Tool
Old May 24, 2019 | 11:58 AM
62KR's Avatar
62KR
TPMS Relearn Tool
Was looking for a TPMS relearn tool. I know some of you have purchased them. What is a good one that will work correctly with a 2017 Super Duty?
Thanks
Old May 24, 2019 | 12:22 PM
wicked 2018's Avatar
wicked 2018
Amazon Amazon
Old May 24, 2019 | 12:31 PM
1956Fatfenders's Avatar
1956Fatfenders
The "Amazon" tool listed above is what I use, but I do not follow the procedure in the manual. I would have to double check, but I believe this process is correct> https://www.tpmsrelearn.com/2016/12/08/ford-1/
I'm sure someone will chime in and verify.
Old May 27, 2019 | 07:03 PM
Section179's Avatar
Section179
You sure you need one?
I’ve moved wheels all around and off and on and haven’t needed one.
Old May 27, 2019 | 07:43 PM
FOURBYBUD's Avatar
FOURBYBUD
They are self learning. No tool required.
Old May 27, 2019 | 09:05 PM
WildWestNAZ's Avatar
WildWestNAZ
Is this the same tool that would allow the sensor to be set to a lower level psi when the light actually comes on in the dash?
Old May 28, 2019 | 05:25 AM
Section179's Avatar
Section179
Thats done with forescan not a tpms tool.
hello113
Sep 23, 2017 10:55 PM
sand1
Dec 9, 2015 07:14 AM
fonefiddy
Garage & Workshop
May 20, 2007 08:03 PM
jrs_big_ford_f150
Garage & Workshop
Jan 24, 2003 12:36 PM
