Headliner depth before damage
Old May 23, 2019 | 10:36 PM
turbogus's Avatar
turbogus
Howdy from Oregon where we kiss where the sun don't shine (on account of the incessant rain)
Strayhound (my van) is a 1998 E150 Club Chateau window van.
I'm looking to mount my venerable old CB radio centered on the ceiling as I did on my '81 E150. Is there some sort of membrane that I'd be screwing into ?
Or, am I better off using molly screws? Please advise.
Thanks and a lift of the lynch lid
Gus
Old May 24, 2019 | 04:24 AM
JWA's Avatar
JWA
The headliner for your year is nothing more than a foam sheet pressed into its shape---there's nothing strong enough in it that'll support a CB radio or similar device weighing that much. Its actual depth would be between 1/4" and 3/8" depending where you'd measure.
Above the headliner is the steel roof with no sort of structure between the left-to-right roof rail at the front and the B-Pillar support just behind the front seats. I'm assuming you don't have a raised fiberglass roof which would make mounting something screwed into the now-covered out-of-sight steel roof.
Old May 24, 2019 | 09:19 PM
Spaznaut's Avatar
Spaznaut
If your headliner is in real good shape you could possibly sandwich a stronger material (metal, wood) to give you a bigger footprint but I don't know if I'd trust it to last. A long piece screwed into the reinforcement right behind the seats and extended toward the front may be adequate. I did this to mount a tv in my van.
Old May 25, 2019 | 04:11 AM
JWA's Avatar
JWA
^^^ That's a good suggestion too---removing the headliner is relatively simple and doing so shows how the roof was originally constructed perhaps giving an idea how to add a more substantial radio mounting material between the metal roof and headliner.
Again the only real concern is NOT having any screws come in contact or go through the metal roof.
Old May 31, 2019 | 04:41 PM
turbogus's Avatar
turbogus
Thanks for your responses guys. I may mount this radio to the engine doghouse, or perhaps build a between the seats lockbox that I can mount the CB and mobile scanner into.
turbogus
35
Feb 24, 2025 02:13 PM
Remford
Mar 23, 2012 06:11 PM
Aero-fan
Aerostar
16
Aug 4, 2010 07:16 PM
The Fish
1978 - 1996 Big Bronco
17
Sep 10, 2004 01:09 AM
xltcrunch
Jul 30, 2004 04:07 PM
