460 Cruise Control
Old May 12, 2001 | 11:51 PM
shortk's Avatar
shortk
460 Cruise Control
I have a 1987 E350 Carbureted 460 and for the second time the cruise control module has stopped working. Both times, the diaphram developed a leak after a couple of years of use. The local Ford dealer wants $132 (again). Does anyone know of a discounted dealer for a replacement? I'm considering a junk yard unit, if I can find one that holds vaccuum. When I went to the local yard, the counterman said "part numbers are important". I found a bunch that look like mine and hold vaccuum, but none with the exact part number. Any info on part numbers would be helpful too. Thanks
Ken
Old May 13, 2001 | 06:25 AM
otto's Avatar
otto
460 Cruise Control
I would definately go for a junkyard unit, as long as the cable end that goes to the carb is the same i dont see why anyone one off a later model truck wouldnt work, i wonder why you keep poping the diapham, if your still uncertain if it will work try a hollander interchange manual, available in reference section of most libraries
Old May 14, 2001 | 10:37 AM
bjoern's Avatar
bjoern
460 Cruise Control
try http://fordpartsonsale.com they usually have pretty good prices.
1988 F-150, V8, 5.0L (302ci), 5spd, SuperCab. Shorty headers, K&N filter, MSD 6a ignition, Accel 300 8.8mm race wires, Accel supercoil, Accel rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon: Dual exhaust.
http://brembs.net/cars/FordPU.html
Old May 14, 2001 | 11:30 PM
PAUL_2's Avatar
PAUL_2
460 Cruise Control
