Headlight switch to instrument cluster wiring problem
77 F150. When I turn the headlights on, the right turn signal indicator on the dash lights solid and the backlighting does not come on. The right turn signal does not light up outside the truck. If I use the right turn signal, it does flash but slowly. It would appear the voltage for the backlighting is going to the turn indicator but I can't figure out how. Pulled the cluster out, pulled the light switch out. Cleaned and greased both. Traced voltage on the light switch and it looks correct. It's tough to do the same on the cluster with little slack on the wires. Any ideas would be appreciated
02-01-2013 10:47 PM
widgetsmama
07-12-2012 05:28 PM
78 F150
25
06-29-2011 01:46 PM
mvtofino
07-01-2007 08:02 PM
scottlane
21
10-04-2005 08:27 AM
