2019 door jambs
Old May 20, 2019 | 01:29 PM
Rtr2017!'s Avatar
Rtr2017!
2019 door jambs
Maybe a silly question, maybe not.
Have had 19 F350 6 months. Opening both front doors now cause a popping sound at the same place....appears or sounds like the plastic piece in the middle of door. I “Wd-40’d” the hinges, etc...and still pops when opening, instead of nice and quiet.
Any suggestions?
Old May 20, 2019 | 05:00 PM
jimzpsd's Avatar
jimzpsd
Any suggestions?
If it sounds like its coming from the middle of the door, and/or plastic, then why apply WD-40 to the hinges? (Also, WD-40 is not a lubricant, it is a solvent that can wash away lubricant.) Anyway, check to make sure the plastic step panel (above the rocker panel) is laying flat at the entrance, and all moldings are secure.
Old May 21, 2019 | 01:32 PM
camping nut's Avatar
camping nut
Also check the strap that stops the door from opening to far.
Old May 21, 2019 | 09:58 PM
Rockinfigs's Avatar
Rockinfigs
I have the same problem but on my driver's side rear door on 19 f350
Old May 21, 2019 | 10:16 PM
WildWestNAZ's Avatar
WildWestNAZ
Try a grease, white lethium should work better then WD. WD is a water displacing formula, not a solvent
ste24vie
Apr 17, 2013 02:23 PM
99expy
Apr 9, 2010 01:30 PM
tcoates
Mar 4, 2009 05:43 PM
XNrepair
Nov 28, 2006 10:04 AM
umdstang
1997 - 2003 F150
Feb 11, 2004 04:53 PM
