Serial #
Old May 20, 2019 | 01:02 PM
ynot321AB1's Avatar
ynot321AB1
Serial #
I found, after scraping years of crud off, a serial number on the right front frame rail and wonder if anyone can tell me what it is.
The figure of a star97HC18074Ithen another star. The last image is an I as in Iowa.
Old May 20, 2019 | 03:01 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
That should be your VIN number which loosely decodes to 1949 six cylinder engine truck. I'm sure others can elaborate...
Old May 20, 2019 | 03:05 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
I'm a '53-'56 guy, so don't hold me to this:
9=1949
7H=6 cylinder
C=1/2 Ton (F1)
18074=sequence number
I=Are you sure it isn't a poorly stamped #1?
The stamped stars were to prevent tampering with the number and/or to mark the beginning and end.
My source: https://www.f100central.com/identify-your-truck
Old May 20, 2019 | 04:03 PM
52 Merc's Avatar
52 Merc
I was used for 1, so the unit number would be 180741. That would be in the range for a 1949 truck, The rest of the info above would be correct, F1 6 cylinder. And that's all there is to know from the serial frame stamping. If you can see any hand stamped numbers/letters across the firewall, near the cowl seam, we can decode those for you to add additional info about your truck.
Old May 20, 2019 | 07:39 PM
EffieTrucker
Ah, I didn't know that one. It doesn't make sense, but it does make sense. It makes sense the year's trucks would be in the 100,000s, not 10,000s.
Thanks, Wayne.
Old May 21, 2019 | 12:14 PM
ynot321AB1's Avatar
ynot321AB1
Thanks to all for the information, it is nice to have a place to get good info
ready59
24
Nov 2, 2023 08:18 PM
Ironbeard
Apr 29, 2019 10:49 AM
cretehead
Dec 10, 2013 11:16 AM
mavereck70
1947 and Older Ford Trucks
Dec 21, 2011 06:43 PM
NiftyLittle'50
Dec 27, 2010 12:20 PM
