What is the cheapest quality lift kit on the market? I'm not looking for a extremely large lift just enought to fit bigger tires under the 1999 standard cab 2wd I have?
Thanks,
Cliff
Cheap and quality usually don't go together......
But you can most likely get away with just a body lift, if you just want bigger tires. $150 should be about the starting price for a "2-3" lift and if you can install it yourself that would save you alot too. Shop around and you just might find a deal!
