Remote start questions
Old May 19, 2019 | 03:39 PM
Dieseloholic1's Avatar
Dieseloholic1
Is remote starters possible for the 1985 f250 if so how well do they work and what do you guys recommend
Old May 19, 2019 | 06:23 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
sure it's possible ... I've seen a few advertise 1987 and up remote start up to 1 mile the ones I've seen run just under 300 bux but I was never really interested in it, Google is yer friend, I could post a couple links but since I don't have experience with their products I can't say which is better .... so just saying YES it is possible.
Old May 19, 2019 | 07:32 PM
Dieseloholic1
That's good to know it could definitely save me an extra trip in the snow I'll do some digging
Old May 19, 2019 | 09:31 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
one thing I might add is that all the ones I have seen are for AT only not for Manual Tranny,
I guess you could rig up a Neutral Safety Switch for an MT and Bypass the Clutch switch IF you have a Manual Tranny and use the Set Emergency Brake Switch for additional Safety.
BUT you didn't state what Tranny you have in your OP
Old May 19, 2019 | 09:34 PM
Dieseloholic1
That's my bad it's an automatic c6 trans that is good to know about the manual though
Old May 19, 2019 | 10:13 PM
DarkOverCast's Avatar
DarkOverCast
AutoZone used to sell a cheapo one for roughly a hundred bucks, probably not the best, but a buddy of mine had one for a couple years and it seemed to do the trick.
I'm sure places like Amazon and EBay are full of them. There's not much to em, they just flip relays that jump around the ignition switch.
You'd probably have to find one with a programmable delay or something to let the glows cycle
Old May 19, 2019 | 10:22 PM
Dieseloholic1
Awesome I'll look into it thank you everyone for the help so far
Old May 20, 2019 | 11:27 AM
RaymondIV's Avatar
RaymondIV
Don't really know how you'd solve the glow plug issue. Depending on the outside temp effects how long the glow plugs stay on. And then for the glow plugs to be effective you have to hit the starter right after the plugs shut off. Especially important if you live in snow climates like you said you do.
Old May 20, 2019 | 11:48 AM
Dieseloholic1
You have a great point I wonder if this would work in the long run or if I'd just waste money
Old May 20, 2019 | 12:20 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
OK this is one of the sites I've seen that do Vehicle Specific Remote Start, I guess they are able to deal with the GP issues....
https://codealarmremotes.com/ford-f-...e-starter-kits <<===== you might like to at least talk to em and see how they handle problems that you might have.
Arduino could be used for a DIY project if you can write code ..... you could use various sensors with an Arduino to control the GP's too.
If ya get bored you can search "arduino remote engine start" without the quotes and that will get you started in that direction.
Old May 20, 2019 | 12:23 PM
Dieseloholic1
Awesome thank you for the information
Old May 21, 2019 | 08:58 AM
Olds64's Avatar
Olds64
You also might consider plugging in your block heater and putting it on a timer. With 2 or 3 hours of block heater in the morning your truck could probably start without GPs. Then just wire the remote starter normally.
Old May 21, 2019 | 10:13 AM
Dieseloholic1
It's a good idea but I live off grid so the only time block heater gets used is when I'm in town at a friend's place
Old May 22, 2019 | 04:48 PM
tjc transport's Avatar
tjc transport
i ain't rite
i have a viper remote start on my 02 diesel. you have to pay extra for the glow plug timer module. and unlike a gas unit that stops spinning the starter when the engine fires, the diesel unit spins the starter for a set time. my 02 is set for 6 seconds crank time, because in winter it takes about 6 seconds to cold start.
but if i use it on a hot engine the engine will start and the starter will still spin until it times out.
Old May 23, 2019 | 10:29 AM
Dieseloholic1
Awesome that's good to know does anyone happen to have a compustar been looking into those as well would love some feedback
